Coefficient of friction problem
The problem involves a block sliding down an incline, specifically focusing on calculating the coefficient of friction after determining the frictional force and the normal force acting on the block.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to find the coefficient of friction using the relationship between frictional force and normal force but expresses uncertainty about calculating the normal force on an incline. Participants suggest using a free body diagram and trigonometric functions to resolve the normal force.
Participants are actively discussing the method to find the normal force, with some providing guidance on using trigonometric functions. There is an ongoing exploration of how to apply these concepts without reaching a definitive conclusion.
There is a focus on understanding the components of forces acting on the block, particularly in relation to the incline's angle and the gravitational force. The discussion reflects a need for clarity on the application of trigonometry in this context.
Sheneron
A 4.00 kg block starts from rest at the top of a 30° incline and slides a distance of 2.10 m down the incline in 1.30 s.
I solved for the frictional force acting on the block and got 9.64 N.
I need to solve for the coefficient of friction. I am having some trouble figuring that out. I am not sure how to find the normal force and once i get the normal force do I use the formula force(friction) = mu * normal force
Any help would be appreciated.
F(friction)=mu*F(normal), where F(normal) is the force perpendicular to the surface of the plane that the block is sliding on. It comes from the weight of the block itself. Draw a free body diagram of the block to find the normal force, you'll have to use a bit of trig to get it. Good luck :)
If i multiply the mass by gravity to find the force of it as if it were not on an incline, and then multiply that by the sin of 30, does that give me the normal force?
no it would be cos 30
So it would be 9.8*4 = 39.2, but then do you divide that by cos 30, or multiply it?
if you draw a diagram of the components of the force you will be able to answer this type of question much more easily. You multiply by cos 30
Ok i see that, thank you for your help
  • · Replies 16 ·
  • · Replies 37 ·
