Why are electron and hole currents zero at thermal equilibrium?
The discussion centers on the question of why electron and hole currents are considered to be zero at thermal equilibrium in semiconductors. Participants explore various theoretical justifications and physical interpretations related to this concept, including algebraic derivations, phenomenological arguments, and thermodynamic considerations.
  • One participant seeks an algebraic derivation to understand why currents must be zero at thermal equilibrium, noting that many resources assume this as a trivial result.
  • Another participant suggests that any flux can be related to the gradient of a generalized potential, specifically using the electrochemical potential, and argues that if the electric field is zero and carrier concentration is uniform, then the flux must also be zero.
  • A different participant questions the generality of the previous argument, pointing out that in the case of a p-n junction at equilibrium, the concentration and electric potential are not uniform, yet the current densities are still zero.
  • One participant proposes that if the electron flux were not zero, electrons would accumulate on one side of the sample, which is not observed experimentally. They argue that while thermal generation and recombination occur, the diffusion process is undirected, leading to zero net flux.
  • Another participant introduces a thermodynamic perspective, suggesting that non-zero flux in the absence of a driving force would decrease the system's entropy, which contradicts the Second Law of Thermodynamics.
  • A participant reiterates the alignment of Fermi levels in a p-n junction at thermal equilibrium, explaining that without external energy, there will be no current due to the potential barrier between the two sides.
Participants express differing views on the justification for zero currents at thermal equilibrium, with no consensus reached on a single definitive explanation. Some arguments are challenged, indicating ongoing debate and exploration of the topic.
Participants highlight various assumptions and conditions, such as uniform carrier concentration and the role of electric fields, which may influence the validity of their arguments. The discussion reflects the complexity of the topic and the need for careful consideration of different models and interpretations.
Tony
Hi, I'm currently studying in an introductory semiconductor course where we use the following equations (numbers 1-5 on the first page):
http://web.mit.edu/kimt/www/6.012/TheFiveEquations.pdf
as a model of the underlying physics.
Now, it is claimed that at thermal equilibrium, we can take J_e and J_h to be identically zero. As I understand it, the requirement of T.E. allows us to state that the derivatives w.r.t. time are zero. However, I'm not certain as to why we need to mandate that the currents are zero.
Of course there's the intuitive notion that if there are currents, then things are moving and thus are not "at equilibrium"; but what I'm looking for is an algebraic derivation from the physical equations that restrict the current to be zero. However, I have not had too much success so far, and most resources just seem to assume that J_i = 0 at thermal equilibrium as a trivial result.
Can anyone give me some suggestions on how to begin?
Here's a justification approach: Any flux [itex]J[/itex] (energy, matter, momentum, etc.) can be related to the gradient of a generalized potential:
[tex]J\propto-\nabla\Phi[/tex]
For charge carriers, we want to use the electrochemical potential:
[tex]\Phi=\mu+q\phi[/tex]
where [itex]\mu[/itex] is the chemical potential (related to concentration), [itex]q[/itex] is the carrier charge, and [itex]\phi[/itex] is the electric field. Now, if we assume that the electric field is zero and the carrier concentration is uniform, then the flux must be zero. Does this sound reasonable?
Actually, I'm not sure I'm convinced with that argument (if I understand you correctly).
We use the claim that the flux is zero in order to obtain a relation between carrier concentration and the electric field. (Equations 1 and 2 in the pdf.) In particular, we use this to analyze the case of an abrupt p-n junction where at equilibrium neither the concentration nor the electric potential are uniform, but the current densities are zero.
This is identical (I think) to your formalism, where the conclusion is that [tex]\Phi[/tex] may be uniform while each of its components are not. Given this example I'm not so sure about the generality of your argument.
Well, another way of looking at it is, if the electron flux isn't zero at thermal equilibrium, why aren't all the electrons piled up on one side of the sample? That just isn't experimentally observed.
One could argue that electrons and holes are forming on the left side of a sample, diffusing, and recombining at the right side. But you could just as well argue that they're diffusing similarly towards the left side. Thermal generation and recombination do occur, but the diffusion process is undirected, and thus the electron and hole fluxes are zero.
I realize these are "softer" arguments than you're looking for. But the fact is that all diffusion relations are phenomenological. Fick's Law, whose general form I wrote above, is phenomenological.
The only other approach I can think is thermodynamical: the coordinated motion of carriers (a non-zero flux) in the absence of a driving force would decrease the entropy of the system, which is prohibited by the Second Law.
Look at the pn-junction : at thermal equilibrium, both of the Fermi levels are aligned. So the Fermi level of the p type semiconductor is aligned with that one of the n type semiconductor. This implies that it's going to cost energy to :
1)get electrons from the n side to the p side
2)get holes from the p side to the n side.
So, without providing that energy, ie by a forward bias, there will be no current because of the potential difference over the junction.
More here :
http://hyperphysics.phy-astr.gsu.edu/hbase/solids/pnjun2.html#c1
marlon
  • · Replies 0 ·
  • · Replies 16 ·
