This is very confusing multiple choice question
The discussion revolves around a multiple-choice question related to concepts in relativity, specifically addressing statements about kinetic energy, proper time, proper length, and relativistic effects. Participants are exploring the validity of various statements and their implications in the context of physics.
  • Participants express uncertainty about specific statements, with some providing reasoning for their beliefs about the truth or falsehood of each option. There is an emphasis on understanding the concepts rather than simply providing answers.
Some participants have offered insights and reasoning for their answers, while others are questioning the interpretations of certain statements. There is a mix of agreement and confusion regarding the definitions and implications of the concepts discussed.
Participants reference a textbook for clarification on concepts, indicating that definitions and interpretations may vary based on the source material. There is also mention of the challenge in determining the correct answers based on the phrasing of the questions.
Evergreen
Which of the following statements are true? (Give the letters, i.e. ACD)
A) One can calculate nonrelativistically when the kinetic energy of an object is large compared with the rest energy of the object.
B) The proper time interval is the shortest time interval measured in an inertial reference frame.
C) The proper length of a meter stick is not always a meter.
D) The total kinetic energy of a body is limited, since its speed can never exceed `c'.
E) A moving clock runs slow.
F) The length along the direction of motion of moving objects are shorter than when they are at rest.
G) Relativistic effects are especially important when speeds are close to the speed of light.
if anyone could answer it, you are the man
I can answer it, but that won't help you learn much. Why don't you tell us your thoughts on each part? We'll help you understand why each is true or false.
- Warren
for A) no clue
B) true,
C)true
D)false
E)true , on book
F) true, on book
G) tricky, because i don't know what he means by important,...no clue
i tried different arrangements, and they were all falst: ABEF,BCEF,BCDEF.ABCEFG.ABCEF.BEF,BEFG, these are all wrong, panicing...
Don't just say "true" or "false." Please tell us your reasoning as to why you think each is true or false.
We don't just give out answers here; we prefer to help students actually understand what they're doing.
- Warren
ok,
for A) i really have no idea what it's talking about
but B) shortest time in frame were object and observer are at rest, the rest is proper time indicator, so it's true
C) proper lengh, it's mentioned in the book, that objects shrink if moving relative to an observer L0 => proper length
D)false because even though v is limites, m isn't as in formula KE = mC^2
E)this is in my physics book
F) also
G) no clue...but i think the denominator becomes zero when v approached to c, so it's not defined, and therefore, no relativistic effects? am i right?
A) The concept of 'rest mass' doesn't exist in Newtonian physics, so no, you cannot calculate it relativistically. false
B) You are correct, the shortest measured time between two events is always is the proper time, which is experienced by an observer at rest with the events. true
C) The "proper length" of an object is its length measured by an observer at rest with respect to it. The proper length of an object never changes. false
D) You are correct, the kinetic energy can go to infinity; it does so as v approaches c.
E) "Moving clocks run slow" is not a well-formed statement. It is true that a stationary observer will observe a moving clock as running slow, but that doesn't mean the clock is doing anything different in its own rest frame. To an observer moving along with the clock, the clock does not do anything out of the ordinary. false
F) false for the same reason as E. Nothing ever changes in the object's rest frame; changes are only seen by observers in relative motion to the object.
G) It's true -- the closer an object is to moving at light speed, the larger is gamma, and thus the more pronounced the deviation from Newtonian physics.
Please let me know if you did not understand any of these answers.
- Warren
on my book,
"clocks moving relative to an observer are measured by that observer to run more slowly(as compared to clocks at rest) => time dilation" p.804
"the length of an object is measured to be shorter when it is moving relative to the observer than when it is at rest" p.809
my book is GIANCOLI
then, isn't E & F are both true then!?
Your quotes mention an observer. Questions E & F do not mention an observer. Questions E & F would only be correct if they were modified to agree with the book.
- Warren
so the answer should be BG ? but...i tried it, still wrong?
  • · Replies 18 ·
18K
10K
