Derivation of the key principle statistical Mechanics
The discussion centers on the derivation of a key principle in statistical mechanics, specifically the probability of a system in equilibrium having a certain energy level, as expressed through the partition function. Participants explore various references, derivations, and the foundational assumptions underlying statistical mechanics, including the treatment of distinguishable versus indistinguishable particles.
  • One participant seeks a detailed derivation of the probability expression related to the partition function, questioning the complexity of the derivation and Boltzmann's original contributions.
  • Another participant suggests McQuarrie's and Hill's books as references for a complete derivation, mentioning the use of Lagrange multipliers in determining state distributions.
  • It is noted that Boltzmann initially explored statistical mechanics for dilute gases, while Gibbs contributed significantly to the conceptual framework involving ensembles.
  • Several participants express interest in the validity of the assumption that each state has equal likelihood, questioning the conditions under which this assumption holds.
  • One participant raises concerns about the completeness of the proof, particularly regarding distinguishable versus indistinguishable particles and the implications of quantum effects.
  • Another participant mentions that Fermi-Dirac statistics address indistinguishable particles, suggesting that the derivation should not be merely an empirical addition to classical statistics.
  • Feynman's book is referenced, indicating that it begins with distinguishable particles before addressing different statistical requirements.
Participants express differing views on the derivation of statistical mechanics principles, particularly regarding the treatment of distinguishable and indistinguishable particles. There is no consensus on the completeness of existing proofs or the foundational assumptions, indicating ongoing debate and exploration of the topic.
Participants highlight limitations in the current understanding, including the dependence on the assumption of equal likelihood of states, the challenges of ergodicity, and the implications of quantum mechanics on statistical mechanics derivations.
bilha nissenson
I am looking for educational derivation( or any available and detailed) of the key principle of statistical mechanics:
If a system in equilibrium can be in one of N states, then the probability of the system having an energy En is (1/Q) e-En/κT
Q is the partition function.
I have looked it up in some books, and did not find a real derivation; perhaps the derivation is too complicated? I am wondering if Boltzmann was the first to derive it, and if his derivation is correct, or it was revised since then?
A complete derivation can be found in McQuarrie's Statistical Mechanics, and probably in Hill's book too, which should be easier to find. It relies on the use of Lagrange multipliers to satisfy the particular constraints of an ensemble while determining the most likely distribution of states.
Boltzmann was the first to explore this area for dilute gases, and the work was relatively easy because the gas molecules can be assumed to be independent. It was Gibbs, however, who came up with the idea on which stat mech is based. He envisioned a virtual ensemble of systems, all identical to the original system in bulk properties, but different in their arrangement of microstates, and he applied thermodynamics to the ensemble. Genius!
thank you I will look it up
A really nice reference is Callen (thermodynamics and an introduction to thermostatistics). Alas, quantum proofs are easier to draw than classical ones (have a look in Landau, Huang and Khinchine books, technical), but you really don't need QM (that is discrete states over the phase space) to derive this kind of result. Pauli stat mech book is also really excellent, small and straightforward.
The proofs not that hard and I believe it can be found on Wikipedia. I’d be more interested in validity of the assumption that each state has an equal likelihood. How can we justify this and under what circumstances is it true?
Is this assumption the only unproved one? i.e. that each state has the same liklyhood?
I am still trying to understand the proof, it does not seem complete to me , I thoght that maybe it I am missing something that everybody sees?
Well, it depends on the constraints that act on the physical system of interest. From a dynamical point of view, the basic assumption is that the system dynamics must be ergodic. Roughly speaking, it means that the phase space must be densely covered by the system trajectories. This kind of assumption cannot be demonstrated, as far as I know, and is clearly wrong in the case of nonequilibrium dynamics (transient states). Another kind of argument is entropic/information theory-like (entropy maximization with respect to the applied constraints, applied temperature, pressure, chemical potential, ...). Entropy maximization is one of the postulates of stat mech and thermodynamics, but it can also be demonstrated on the basis of the Boltzmann H-theorem (kinetic theory)... All this kind of **** is very well written in Pauli's book, "stat. mech.", Dover (see also Huang). My feeling is that looking at the web won't be a great idea for this difficult fundamental intricated subject... Actually, there is a lot of research on this subject, because nowadays nano-objects are more and more working out of equilibrium regimes, and equilibrium stat mech barely don't apply to them (see Gallavotti-Cohen fluctuation theorems, Jarzynski and Crooks equalities, Anosov systems, Ruelle SRB measures...).
I have the following problems, which I feel are connected,
1. It seems to me that the proof is for a set of distinguishable particles, and I did not see it developed for a set of indistinguishable particles.
2. You can say that this is because it is classical and classical particles can be distinguishable, but from the other side, the probabilities have a quasi continuous spectrum, this is important for the proof. So we are looking at a very small volumes, (I was also wondering how small can we go) that must bring in the quantum effects, so are the P distinguishable in as small volume that we need?
3. So perhaps what I am looking for is a proof that is true for quantum indistinguishable particles.
Wikipedia mentions that Fermi-Dirac statistics deal with indistinguishable particles. As for how small you can go if you read the discussion part of the wikipedia page this is discussed somewhat. I believe there is higher order sterling approximations that are dealt with in modern physics books. Also if you are looking for more issues to question this is discussed to three posts back by SeniorTotor and here's his quote: "All this kind of **** is very well written in Pauli's book, "stat. mech.", Dover (see also Huang)."
The Fermi Dirac statistics, is added on top of the classical statistics, I thought it should be possible to derive the formulae on the basis of indistinguishable particle to begin with, and not add it on as an empirical fact of the quantum mechanics.
Why do you believe the derivation is empirical. I'll look at it to see if I can follow it. Where are you stuck?
I looked in Feynman’s book, ‘statistical mechanics’, The derivation starts with a set of distinguishable particles, and then he continues to add the requirements of the different statistics.
  • · Replies 25 ·
  • · Replies 116 ·
10K
