How Do You Solve Complex Chemistry Titration and Reaction Problems?
  • Thread starter Thread starter nx01rules
    Chemistry Stuck
This discussion revolves around solving complex chemistry titration and reaction problems, specifically focusing on the calculations related to iron (II) ions in a solution and the stoichiometry of reactions involving magnesium and acids. The scope includes theoretical calculations, stoichiometric reasoning, and practical application of chemical equations.
  • Homework-related
  • Post 1 presents two questions involving titration and stoichiometry, seeking assistance on how to calculate concentrations and masses based on given reactions.
  • Some participants suggest using the number of moles and mole ratios to find the concentration of iron (II) ions in the solution, referencing the reaction with potassium permanganate.
  • Others propose that the excess acid can be ignored in the calculations for the titration problem, focusing instead on the permanganate's contribution to determining the moles of iron (II) present.
  • One participant mentions that the mass of iron (II) ions calculated from the reaction will be less than the original mass of the wire due to impurities.
  • A later reply provides a detailed calculation for the concentration of iron (II) ions and the percentage by mass of iron in the original sample, but does not confirm its correctness.
Participants express uncertainty about the calculations for Question 1, with some suggesting methods while others question their understanding. There is no consensus on the correct approach or final answers for the problems presented.
Participants rely on stoichiometric relationships and molar calculations, but there are unresolved assumptions regarding the purity of the iron wire and the handling of excess reagents in the titration.
This discussion may be useful for students studying chemistry, particularly those dealing with titration problems and stoichiometric calculations in reaction scenarios.
nx01rules
Hi, I am doing chemistry at my school, and I am currently stuck on a couple of questions that I don't know how to complete. Here are the questions:
Question 1. An 8.75g. sample of iron wire was dissolved in excess sulfuric acid. All the iron present formed iron (II) ions. This solution was made up to 1.00 L. with distilled water. A 20.0 mL. sample of this solution was pipetted into a conical flask and titrated with 0.025 mol/L potassium permanganate solution. An average titre value of 22.1 mL. of permanganate was required to reach the equivalence point
a) Calculate (showing all the working) the concentration of iron (II) ions in the 1.00 L. solution if the equation
for the reaction was
5Fe2+(aq) + 2MnO4-(aq) + 16H+(aq) = 5Fe3+(aq) + 2Mn2+(aq) + 8H2O(l)
b) Calculate the % by mass of iron in the original 8.75g sample of wire.
I am thinking that you need to work out the number of mols of Iron (II) present, using n=m/M, and then use n=CV, and rearrange it into C=n/V and work out the concentration. But I also have a nagging feeling that you need to take into account the mol ratios and use something like n(Fe)/5 = n(MnO4)/2. But I can't use n(Fe), because it is a solid and I need to use m/M for it, and it doesn't have concentration in that equation, which is what I am trying to work out.
Please, some assistance would be fantastic!
Question 2. What volume of 0.125 mol/L H2SO4 must be added to 1.25 L of 0.10 mol/L HCl in order to exactly dissolve
4.5g of Magnesium? (Show all the working out.)
The equations for the reactions are:
2HCl + Mg = MgCl2 + H2
AND:
Mg + H2SO4 = MgSO4 + H2
I tried to work out Question 2 after I wrote this, I think I may have it right. What I did, was I worked out the number of mols of HCl present:
(I assume you are familiar with n=m/M and n=CV :biggrin: )
n(hcl)/2 = n(mg)/1 (The division bits are dividing each side by their mole ratio, obtained from the equation)
Then I began to work out exactly how much Magnesium would actually react with that certain number of mols of HCl:
(C X V)/2 = m/M (Where m is the mass in grams, M is the molar mass in g/mol)
Filling in all the known values:
(0.10 X 1.25)/2 = m/24.31
After rearranging the equation to get m, I came up with:
(0.125 X 24.31)/2 = m
Therefore, m = 1.52g
So, I found that 1.52g of magnesium will react with the HCl. Now, what is remaining will react with the H2SO4. The
amount remaining is:
4.5g-1.52g = 2.98g
Then, I worked out how much H2SO4 is needed using another stoichiometric calculation:
n(H2SO4) = n(Mg)
C X V = m/M
The remaining Magnesium is used as well to help calculate how much H2SO4 is needed to neutralise what is left of it:
0.125 X V = 2.98/24.31
After rearranging:
V = 0.123/0.125
V = 0.98L
I think this question would be all good and right, if not, please correct me. If it is right, can I please have some
help on Question 1?
Thanks to anyone who can help!
Chemistry news on Phys.org
An update - it seems i DO have Question 2 right after all - so its just Question 1 that I am in the dark about.
So anyone doesn't know how to do this?
I could give it a shot. I'm not completely sure I understand what is going on in the problem though.
I'm thinking it could be done backwards. The acid was in excess so just ignore it. For the permanganate, you know the solution concentration and how much it took; find how many moles of permanganate the titration took. Then use the mole ratio to find how much Fe2 was present.
(x moles MnO4) * (5Fe2/2MnO4) = (y moles Fe2)
The concentration for the 1L solution should be the same as the 20mL sample. Divide (y moles Fe2) by 0.02L and you should get the proper concentration.
I don't understand part B.
Yeah I actually started to think that this problem isn't so hard after all and it doesn't need too much hard thought at all. But for part B, if you work out the number of mols of Fe2+ used IN THE REACTION, you can divide n by Fe's molar mass to work out the MASS of Fe2+ in the solution that was used up. Then, because that will be a smaller value than the original wire, you can find the percentage by mass by going - m/8.75g * 100, where m is the worked out mass. The reason it is less is because the Fe2+ isn't a pure wire. It has impurities in it.
Q1.
a) 5Fe2+ + 2MnO4- + 16H+ = 5Fe3+ + 2Mn2+ 8H2O
No. of moles of MnO4- in 22.1 L= CxV/1000(since the volume is in mL)
= 22.1 x 0.025/1000
=5.525 x 10^-4 mol
Therefore the no. of moles of Fe2+ reacted with MnO4-=5/2 x 5.525 x 10^-4
(since mole ratio of Fe2+:MnO4-=5:2) =1.38125 x 10^-3mol
This 1.38125 x 10^-3 mol of Fe2+ is in 20 mL of the solution.
Therefore, No. of moles of Fe2+= C x V/1000
1.38125 x 10^-3= C x 20/1000
C= 0.0690625 mol/L
b) Fe + H2SO4 = FeSO4 + H2
In 1L no. of moles of Fe2+ is 0.0690625
Therefore the no. of moles of Fe is also the same ( from the equation the mole ratio of Fe:Fe2+=1:1)=0.0690625 mol
No. of moles=Mass/Molar mass
Mass=No. of moles x Molar mass
=0.0690625 x 56
=3.8675 g
This is the actual mass of Fe present in the 8.75 g of wire.
Therefore % by mass of Fe present=Actual mass of Fe/Mass of wire x 100
=3.8675/8.75 x 100
=44.2%
:blushing: Hope that helped!
  • · Replies 0 ·
34K
