Permutations of the letters a, b, c, d, e, f, g
  • Context: Undergrad
  • Thread starter Thread starter Caldus
    Permutations
The discussion revolves around calculating the number of permutations of the letters a, b, c, d, e, f, g with specific conditions on the spacing between the letters a and b. The focus is on combinatorial reasoning and mathematical calculations related to permutations.
  • One participant proposes that the number of permutations with two letters between a and b can be calculated as 5! and similarly for three letters, suggesting a total of 5! + 5! as the answer.
  • Another participant agrees with the initial calculation but emphasizes the need to consider all possible position pairs for a and b, indicating that the initial approach is incomplete.
  • A later reply introduces a revised calculation of (5! * 4) + (5! * 3) and seeks confirmation on its correctness.
  • Another participant points out a missing factor of 2 in the revised calculation, noting that the order of a and b matters unless a is assumed to always precede b.
Participants do not reach a consensus on the final answer, as there are differing views on the factors to include in the calculations and the assumptions regarding the order of a and b.
There are unresolved assumptions regarding the positioning of a and b, and the implications of their order on the total count of permutations.
Caldus
How many permutations of the letters a, b, c, d, e, f, g have either two or three letters between a and b?
My guess for this is that if a and b have to have two letters between them, then there are 5! ways to arrange the rest of the letters, right? Same deal if a and b have to have three letters between them. So:
5! + 5!
Would be my answer. Am I anywhere close with this one? Thank you.
Mathematics news on Phys.org
Your answer is correct for each specific (a,b) position pair. Your have to multiply by all possible position pairs for a and b, e.g. (1,4), (4,1), (2,5) etc. for two spacing, and similarly for three spacing.
Thank you.
I came up with this new answer:
(5! * 4) + (5! * 3) = 840
Am I close here?
You're missing a factor of 2, since a at 1 and b at 4 is different from b at 1 and a at 4, etc., unless you are assuming a is always before b. In that case you are right.
