What Determines a Roller Coaster Car's Speed at the Top of a Loop?
The speed of a roller coaster car at the top of a 50.0-meter diameter loop is determined by balancing the centripetal force with gravitational and normal forces. The centripetal force, represented by the equation f = mv²/r, is not directed downward but acts to maintain the circular motion of the car. To find the speed, the formula v = √[gr/m] is used, where g is the acceleration due to gravity, r is the radius of the loop, and m is the mass of the car. For the given parameters, the calculated speed at the top of the loop is 8.94 m/s.
  • Understanding of centripetal force and its role in circular motion
  • Familiarity with Newton's laws of motion
  • Basic knowledge of gravitational force and its calculation
  • Ability to manipulate algebraic equations for physics calculations
  • Study the principles of centripetal acceleration in circular motion
  • Explore the effects of mass and radius on the speed of objects in circular paths
  • Learn about the dynamics of roller coasters and safety considerations
  • Investigate the role of normal force in various motion scenarios
Physics students, mechanical engineers, amusement park designers, and anyone interested in the dynamics of roller coasters and circular motion.
StephenDoty
As a roller coaster car crosses the top of a 50.0 -diameter loop-the-loop, its apparent weight is the same as its true weight.What is the car's speed at the top?
So the car is under the circle at the top. so the forces acting on the car would be mg and the normal force acting down
My question is, is the force f=mv^2/r going down with the rest of the forces or up against the other forces?
I know that since a = 0 and that a goes toward the center, thus Fnet = 0 and going to the center. But does this mean that F=mv^2/r goes down too?
Thank you.
Stephen
No, the force f=mv^2/r is not going down with the rest of the forces. This force is a centripetal force, which is the force that keeps the car moving in a circular path around the top of the loop. At the top of the loop, the car’s speed must be great enough to counteract gravity (mg) and the normal force (N) to keep it moving in a circular path. Thus, the speed of the car at the top can be calculated by equating the centripetal force to the sum of the other two forces: f = mv^2/r = mg + N or v = √[gr/m] where g is the acceleration due to gravity, r is the loop’s radius, and m is the mass of the car. Plugging in the given values gives us the car’s speed at the top of the loop-the-loop as v = 8.94 m/s.
  • · Replies 16 ·
