Deriving x(t) into A sin (\omega*t + \varphi)
  • Thread starter Thread starter krnhseya
    deriving Sin
The discussion focuses on deriving the expression x(t) from its complex exponential form into a sine function format. The original expression is x(t) = (exp^(-\zeta\omegat)) * (a1(exp^(i\omegasqrt(1-\zeta^2)*t)) + a2(exp^(-i\omegasqrt(1-\zeta^2)*t))). Participants clarify that the sine terms do not cancel out unless a1 equals a2, leading to the final form x(t) = e^{-\zeta\omega t}[(a_1 + a_2)cos(ω√(1-ζ²)t) + (a_1 - a_2)sin(ω√(1-ζ²)t)]. The constant ζ is confirmed as part of the equation.
  • Understanding of complex numbers and Euler's formula
  • Knowledge of exponential decay functions
  • Familiarity with trigonometric identities
  • Basic differential equations
  • Study the derivation of trigonometric identities from complex exponentials
  • Learn about damping in oscillatory systems
  • Explore the implications of ζ in control systems
  • Investigate the use of Fourier transforms in signal processing
Students studying differential equations, engineers working with oscillatory systems, and anyone interested in the mathematical foundations of signal processing.
krnhseya
Derive...
x(t)=(exp^(-[tex]\zeta[/tex][tex]\omega[/tex]t))*(a1(exp^(i[tex]\omega[/tex]sqrt(1-[tex]\zeta^2[/tex])*t)))+a2(exp^(-i[tex]\omega[/tex]sqrt(1-[tex]\zeta^2[/tex])*t))))
into
x(t)=(exp^(-[tex]\zeta[/tex][tex]\omega[/tex]t))*(A sin ([tex]\omega[/tex]*t + [tex]\varphi[/tex]))
n/a
I've managed to get x(t) = (exp^(-[tex]\zeta[/tex][tex]\omega[/tex]t))*((a1(cos[tex]\omega[/tex]*t) + i sin ([tex]\omega[/tex]*t))+(a2(cos[tex]\omega[/tex]*t) - i sin ([tex]\omega[/tex]*t))) then when i simplify things...sin terms cancel out and i end up geting...
exponential term * (a1+a2) * (2cos [tex]\omega[/tex]*t)
Hi,
Is the [itex]\zeta[/itex] a constant here?
No, the sine terms do not cancel out. You have the following.
[tex]x(t)=e^{-\zeta\omega t}\left[(a_1+a_2)\cos\left(\omega\sqrt{1-\zeta^2}t\right)+(a_1-a_2)\sin\left(\omega\sqrt{1-\zeta^2}t\right)\right][/tex].
The only way the sine term will vanish is if [itex]a_1=a_2[/itex], and you did not say that that is the case in your problem statement.
Tom Mattson said:
Hi,
Hello. It is a constant.
Yeah, I figured out that I made a mistake.
that's as far as i can go but i need to combine that into sin like I've posted above.
thanks for the reply!
And, there should be a bracket infront of "sqrt" so exponential part it outside the whole thing.
[edit] I think I got it...Thank you very much! :)
  • · Replies 0 ·
