Thread Closed
right-handed coordinate systems
Share Thread Thread Tools
Feb21-08, 02:39 AM   #1
Everyone tells me that I should use right-handed coordinate systems. But no one tells me what happens if I don't. What is the danger of not using right-handed coordinate systems?
2. Relevant equations
3. The attempt at a solution
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Feb21-08, 03:57 AM   #2
What do you mean? How exactly are you going to "use" left-handed coordinate systems?
It's a convention, nothing more. Your signs will be backwards in some calculations.
(The real reason has to do with the fact that the determinant operator is uniquely determined by a basis AND an orientation. If you choose a different orientation than everybody else, your determinant will be the negative of theirs. It's a convention, but it's a convention that really matters. I'm guessing that this doesn't mean anything to you, and you probably just want to label your axes differently when you're graphing stuff. If so, please disregard.)
Feb21-08, 07:12 AM   #3
Recognitions:
Homework Helper Homework Help
cross product changes too (related to the change in determinant operator)
many things like electromagnetism etc... motivate the use of right hand system as just a convenient way to present certain physical phenomena. But at the end of the day, it is just matter of convention. nothing else
Thread Closed
Thread Tools
Similar Threads for: right-handed coordinate systems
Thread Forum Replies
Converting between coordinate systems? Calculus & Beyond Homework 3
right-handed coordinate system Calculus & Beyond Homework 1
3 dimension coordinate systems Calculus & Beyond Homework 17
Right/Left Handed Systems Linear & Abstract Algebra 2
div an curl in different coordinate systems Introductory Physics Homework 11
