Unveiling the Mystery of Delayed Phone Ringing
  • Thread starter Thread starter Danger
    Mystery
The discussion revolves around the phenomenon of delayed ringing in phones, particularly focusing on the timing discrepancies between multiple phones on the same line, both cordless and traditional. Participants explore the mechanisms behind phone ringing, including the role of internal components and electrical signals.
  • One participant notes that two phones on the same line do not ring simultaneously, leading to delays that can be annoying, especially with multiple cordless phones.
  • Another participant shares an anecdote about a cordless phone that rang despite being completely unplugged, suggesting that the ringing may be generated internally rather than from the phone line.
  • Some participants discuss the concept of "ringer equivalents," which refer to the strength of the ringer in different phones, and how this might affect the timing of the ringing.
  • It is mentioned that traditional phones were rung by an AC signal from the line, while modern phones use a piezo buzzer to detect the same signal, maintaining backward compatibility.
  • Technical details about standard phone line voltages and impedances are provided, including the specifics of the ringing signal and its potential effects.
Participants express various viewpoints regarding the causes of delayed ringing, with some suggesting it relates to the ringer equivalents and others sharing personal experiences that highlight the complexity of the issue. No consensus is reached on a definitive explanation.
Participants mention the quality of the phone bases and handsets as a potential factor in the observed delays, but do not provide a clear resolution to the underlying causes of the phenomenon.
Danger
This has been bugging me for years, but I never thought to ask about it before.
I always thought that the 'ring' trigger signal was just sent to the phone from outside and set it going. What I've noticed, though, is that two phones on the same line don't ring at the same time. It's very annoying. Even worse at home, since we have 2 cordless phones. The base unit on one of them rings first, then the base of the other, then the first handset, and finally the 2nd handset. That's a lot of ringing for someone who doesn't care for extraneous noises.
I can understand that the base unit might have to redirect the signal to its own handset, and thus cause a delay between them (but this is about 2-3 full seconds), but why on Earth are the bases staggered? It happens at work, too, and at my old house with no cordless units at all--just regular extension phones.
Computer science news on Phys.org
I don't have an answer to your question, but I can "one up" you on weird phone behavior. I had a cordless phone COMPLETELY unplugged from the wall (base station unplugged from phone jack and power cord unplugged) and the dang thing would STILL ring whenever a call came in for months (it was dead if I tried to answer it...so I was sure the battery was running out). I finally had to yank out the battery to stop it. (If it rang after the battery was removed, I was going to post about it in S&D :biggrin:).
Anyway, I think that means the ring is generated from within the phone, not from the phone line.
Best way to fix it is to turn off the ringers on all but one phone. That's what I've done. My phone in the living room is still on, and if I'm awake, I can hear that from all the other rooms in the house, but all the other ringers are off, so if I'm asleep, they don't wake me up.
The ringer is inside the phone and is set off by an electrical impulse sent from the phone company. We used to refer to it as the "ringer equivalent". Some old Western Electric phones had ringer equivalents of 5.0 (very strong), some of the free giveaway phones that came out had RE's of 0.0, meaning no audible ring.
I'm not sure what it is causing your problem danger. Perhaps it is the ringer equivalents, probably exacerbated by the quality of the bases sending signals to the handsets.
That must be it, then, since the other phones aren't cordless and the problem is less pronounced with them. Thanks.
Good idea about muting the ringers, Moonbear. I'll give that a try (if W let's me; they're her phones).
Real phones with a dial and a bell were rung by the line (a 48V ac signal which is surprisingly painfull for such a low voltage) modern phones detect the signal and sound a peizo buzzer, the line still sends the same signal, phone people are obsessed with backwards compatibility.
A standard phone line has a 48v DC on hook voltage with about a 600 ohm impedance.
The ring signal is around 90v AC, but it varies a bit.
Yea! Its a bit painful :wink:
I suspect that you, like I, had the experience of installing a phone line at the moment someone called. A SHOCKING sensation!
  • · Replies 152 ·
12K
  • · Replies 66 ·
16K
11K
