How Can Neutrino Spin Be Measured Beyond Decay Processes?
The discussion revolves around the measurement of neutrino spin, particularly focusing on methods beyond decay processes. Participants explore theoretical principles and potential experimental setups that could allow for such measurements, while also considering the implications of neutrino interactions.
  • One participant questions how neutrino spin can be measured given that neutrinos are unaffected by electromagnetic and strong forces, suggesting a need for alternative physical phenomena.
  • Another participant challenges the exclusion of decay processes, noting that they are commonly used to determine particle spins.
  • A thought experiment involving magnetic fields is proposed, with participants discussing whether neutrinos would be deflected due to their lack of charge and magnetic moment.
  • It is suggested that while neutrinos do not interact electromagnetically, their spin could still be inferred from interactions with other particles, such as electrons, which have measurable spin characteristics.
  • One participant proposes that the differential cross-section of interactions involving neutrinos could provide insights into their spin, similar to measurements for other particles.
Participants express differing views on the feasibility of measuring neutrino spin without relying on decay processes. There is no consensus on the methods or principles that could be applied, indicating ongoing debate and exploration of the topic.
Some discussions involve assumptions about neutrino interactions and the implications of their spin, which may depend on specific experimental setups or theoretical frameworks that are not fully resolved in the conversation.
kilokhan
If a neutrino is unaffected by EM and strong forces, and only interacts weakly, how is it possible to measure its spin? I don't mean measurement in a practical sense, as in looking at pion decay.. but how it could be measured in principle. I guess what I mean is are there any physical phenomena where it is a factor (apart from decays).
Why do you rule out decays? That is how most particle spins are determined in practice and in principle.
what about the usual thought experiment used to explain spin, with magnetic fields? do we expect neutrinos to be deflected?
Without thinking too much about it, I think they would not be deflected because they don't have magnetic moment (because they don't have charge...). The magnetic moment of neutrino is less than [tex]0.74 \times 10^{-10} \mu_{B}[/tex] (upper known limit in terms of the Bohr magneton, which is the natural unit)
Now maybe a higher order process I have not thought of right now could indeed deflect this neutrino...
Apart from that, it is possible to deduce the spin of the neutrino from more general principles, without actually measuring it.
Well you said in your first post that they don't interact via the EM-force so have answered that one yourself :-)
We detect neutrinos by looking at how they interact with other particles. A good choice is electrons. Of course neutrinos don't leave a track but electrons do.
The target electrons all have spin 1/2 but they are oriented randomly. We can look at the characteristics of the electrons that are hit to learn stuff about the spin and orientation of the neutrinos.
For example, if the neutrinos had no spin, then the interaction would follow the symmetry of a spin-0 + spin-1/2 system. Since the spin-1/2 systems aren't polarized, the resulting collisions aren't polarized either.
Instead, the neutrinos turn out to have spin-1/2 and they ARE polarized, with their spin aligned in the direction of travel (or antiparallel). You should be able to detect this in the characteristics of the ejected electron.
I would say it can be measured like for every other particle.
Indeed differencial cross-section depends of the spin of incoming and outgoing particles. So looking at the differencial cross-section of well chosen observable (like an angle) will answer your question.
