Maximal ideal question, + invertibility
  • Context: Graduate
  • Thread starter Thread starter sihag
The discussion revolves around the properties of maximal and prime ideals in finite commutative rings, particularly those without unity. Participants explore examples and counterexamples related to these concepts, as well as the invertibility of certain matrices in a specific subring of 2x2 matrices over the reals.
  • One participant seeks an example of a maximal ideal that is not prime in a finite commutative ring without unity, referencing the established result that in rings with unity, maximal ideals are prime.
  • Another participant suggests reviewing the proof of the unital case to identify where it fails, hinting at the behavior of ascending chains of ideals in non-Noetherian rings.
  • A third participant counters the claim that maximal ideals are always prime by providing an example in Z[x], where is prime but not maximal, while noting that the statement holds for Artinian rings and PIDs.
  • One participant proposes examining non-Artinian rings and presents an example involving the infinite descending chain of ideals in Z, identifying 4Z as a maximal but not prime ideal in the rng 2Z.
  • A later reply corrects the initial misunderstanding about the context, affirming that in finite commutative rings with unity, maximal ideals are indeed prime, and provides an example using the ideal {0,4} in the ring {0,2,4,6} modulo 8.
  • Participants discuss the invertibility of matrices in the subring of matrices with equal entries, questioning the implications of singularity and the determinant in this context.
Participants express differing views on the relationship between maximal and prime ideals, with some providing counterexamples to challenge the initial claim. The discussion remains unresolved regarding the specific examples in finite commutative rings without unity.
Participants acknowledge limitations in their examples and reasoning, particularly regarding the definitions and properties of ideals in non-unital rings and the implications of singular matrices in the context of invertibility.
sihag
I'm unable to think of an example of a maximal ideal that is not prime in a finite commutative ring without unity.
Of course the context is, the result stating that in a commutative ring with unity, an ideal is maximal iff it is prime.
Somebody help me out with this ?
Another question is for the ring of 2 x 2 matrices over reals (lets call it M), its subring of matrices with all entries equal (lets call it R) is a ring with a different unity. (wrt usual matrix operations of addition and multiplication)
the unity is 1/2 in each entry.
Of course all non-zero elements of R are invertible, the inverse being (1/4)x (where x is the 'equal entry' for the element of R).
My question is why does this happen, though such matrices belonging to R are all singular.
My own reasoning is that since the determinant is 0 for all matrices belonging to R, we are really not defining anything by the determinant calculation. Also the adjoint of any element of R doesn't belong to R in this case, since the entries will not be equal for adjoint (negatives for the (2,1)th and (1,2)th entry).
But, I'm really not convinced by my own reasons. I know it's tantalizing. Does it have to with the necessary and sufficient criterion relating the determinant with the fact of invertibility of the matrix?
Help me out with this too, someone?
Thank you.
Well, obviously, you have to find where the proof for the unital case fails. Have you tried reviewing the proof with a fine-toothed comb to find where the failure happens? Here, I think the only problem is (hint in white) that if you have an ascending chain of proper ideals, you aren't guaranteed their union is proper. (In particular, this means you're going to have to look at rngs that aren't Noetherian)[/color] (highlight to read)
... My question is why does this happen, though such matrices belonging to R are all singular. ...
Well, I'm not really sure what you mean by "why". But my best guess is that you should look at algebraic properties -- can you think of any unusual equations that the identity of the subrng must satisfy? In particular (additional hint colored white) you might be interested in the idempotents of your rng[/color] (Highlight to read, but only after you've reflected on what I've already said!)
This is not true. For example, in Z[x], a commutative ring with unity, <x> is prime but not maximal. But your statement is true for Artinian rings (and for PIDs).
Hrm... I think I was answering a question different than the one you meant to ask with this section.
Yeah - it looks like you were considering the question of whether or not a proper ideal sits inside a maximal ideal.
As for the original question, my gut reaction was to look at non-Artinian rings, and examine an infinite descending chain of ideals (since ideals are in particular non-unital rings). This actually did produce an example: in Z, we have the infinite descending chain 2Z > 4Z > 8Z > ..., and 4Z is a maximal but not prime ideal of the rng 2Z.
But then I realized that the OP was asking for an example in a finite commutative ring without unity. At first I thought this would be impossible to find, since finite rings are trivially Artinian, but I think I did manage to construct an example. Let S=Z/8Z and let R=2S (the ideal of S generated by 2). R is a finite commutative ring without unity (it has no nonzero idempotents). Now if we let I={0,4}, then this is an ideal of R that is maximal but not prime.
In conclusion: non-unital rings suck.
mistake, i meant in a finite commutative ring with unity, an ideal is maximal iff it is prime.
yes it should work, if we use {0,2,4,6} addition and multiplication modulo 8
{0,4} is maximal but not prime. (2*6=4,under mult. modulo 8, but neither 2 nor 6 belong to the ideal). got it.
What i meant was, it feels counter-intuitive. I've got to think about it more.
  • · Replies 17 ·
