Calculating Absolute and Gauge Pressure in a Gasoline-Filled Container
  • Thread starter Thread starter JWHooper
    Pressure
The discussion revolves around calculating the absolute and gauge pressure in a gasoline-filled container, specifically focusing on a 2.5 m deep container at sea level. The problem involves understanding the relationship between absolute pressure, gauge pressure, and atmospheric pressure.
  • The original poster attempts to calculate gauge and absolute pressure using the formula P = P_0 + Dhg and raises questions about the correctness of their calculations and the meaning of P_0.
  • Some participants clarify the relationship between absolute pressure, gauge pressure, and atmospheric pressure, while also speculating about the implications of gauge pressure in different contexts, such as underwater scenarios.
The discussion is ongoing, with participants providing clarifications regarding the formula and the definitions of the terms involved. There is an exploration of different interpretations of gauge pressure, but no explicit consensus has been reached on the original poster's calculations.
Participants are considering the implications of atmospheric pressure and gauge pressure in their calculations, and there is a mention of the surrounding conditions affecting pressure measurements.
JWHooper
Calculate the absolute and gauge pressure at the bottom of a 2.5 m deep container, if it is full of gasoline (density = 690 kg/m^3). Assume the container is open at the sea level.
P = P_0 + Dhg
P = (690 kg/m^3)(2.5m)(9.8 m/s^2) = (1.69 x 10^4 Pa)(1 kPa/10^3Pa) = 1.69 x 10 kPa (gauge pressure)
(1.69 x 10^4 Pa) + (1.01 x 10^5 Pa) = 1.18 x 10^5 Pa (absolute pressure)
My questions (important!):
1. Did I do these right?
2. Also, what is P_0 in the equation P = P_0 + Dhg?
3. gauge pressure + 14.7 lb/in^2 = absolute pressure ----> true or false? If not, please explain.
Thanks,
J.
I think you've answered your own question with the formula
P = P_0 + D.h.g
absolute pressure = atm. pressure + gauge pressure.
Interesting to speculate whether, if it was all underwater, the gauge pressure would be negative ?
P = P_0 + D.h.g
So, P is the absolute pressure, P_0 is the atm. pressure, and Dhg is the gauge pressure?
Okay. Now, disregarding P_0, did I do the solution correctly?
  • · Replies 23 ·
  • · Replies 31 ·
