Understanding Spinning Black Holes: A Confused Perspective
  • Context: Graduate
  • Thread starter Thread starter Riogho
    Singularities Spinning
The discussion revolves around the nature of spinning black holes, focusing on the concepts of angular momentum, the structure of singularities, and the implications of black hole rotation on spacetime. Participants explore theoretical aspects, observational evidence, and speculative ideas related to black holes.
  • Some participants express confusion about how spinning black holes can have angular momentum given that the singularity is described as a point structure.
  • One participant suggests that as a star collapses into a black hole, it conserves angular momentum, which leads to the black hole's spin.
  • Another participant states that the singularity of a rotating black hole is actually a ring, which contrasts with the idea of a point mass.
  • There is a debate about the existence of observational evidence for spinning black holes, with some asserting that evidence exists while others challenge this claim.
  • One participant proposes that black holes might have a hollow core maintained by anti-energies, speculating about their potential connection to parallel universes.
  • Another viewpoint suggests that the mass of a black hole must spin to exist within the fabric of spacetime, implying that non-rotation would disrupt this fabric.
  • A participant notes that for an outside observer, a black hole has a surface that may rotate, raising questions about the nature of that surface.
Participants express multiple competing views regarding the structure and behavior of spinning black holes, and the discussion remains unresolved with no consensus reached on key points.
Some claims rely on specific definitions of mass and angular momentum, and the discussion includes speculative ideas that are not universally accepted or verified.
Riogho
Okay, I know there is observational evidence for spinning black holes, so therefore I must be confused about something, and I want you to tell me what.
If you have a star that is spinning, therefore it has orbital angular momentum (mass revolving around a point), then as it is collapsing in a black hole, it shoots out particles that probably take some of that with it, but not all, and because angular momentum is conserved the black hole will spin.
However, it is my understanding that the actually 'massy' part of the black hole is a simple point structure with a large mass and density with (almost?) infinite curvature. But if it is a point, there is no mass to revolve around this point therefore no more orbital angular momentum.
I've probably screwed up already, but my idea is that like an electron (which is a point particle that has angular momentum) instead of having orbital angular momentum it is transformed into spin angular momentum, (where it acts as if it is 'spinning' though it does not) this would seem to explain it away.
Correct? No?
Thanks for the help.
The singularity for a rotating black hole is a ring.
you have to believe in the mathematics!
No, I don't think there is. For spinning pulsars etc, yes, but not (yet!) for black holes.
Correct? No?
Yup, your comparison with an electron seems as good as any.
A black hole is a "simple point structure" (well, actually it's a ring structure, as George Jones says, but the ring doesn't rotate).
And it's very difficult to accept that point structures can have gravity or angular momentum or charge.
But if you believe they exist at all, you have to believe in the mathematics, and the mathematics says they do! :smile:
Awkward, isn't it?
A rotating black hole 'rotates' in the sense that it 'drags spacetime around it'.
The ring previously mentioned comes from the relatively large amounts of anti-energies. These energies have been discovered within the laboratory. They, however, are extremely rare in the universe but when the universe's matter is collected by objects such as black holes it also exhibits a higher concentration of these energies which are actually repulsive to each other which helps to provide the force necessary to maintain a hollow core, the inside of the ring, of a black hole. Many physicists speculate that these rings may actually be the gates into other parallel universes with altered (usually considered inverse) physical governing forces.
Just a thought, but my view is the black hole mass must spin to exist in the space time fabric in our universe and by spinning creates a vortex we all know, if it didn't it would tear the fabric and drop to the other side of space time as we know it, what it does there is speculation, I have ideas but not dot this discussion, our fabric heals it's self, black holes and it's core mass must rotate to exist in our universe.
For any outside observer, a black hole only has a surface, and that surface probably can rotate.
  • · Replies 0 ·
  • · Replies 18 ·
  • · Replies 22 ·
  • · Replies 57 ·
