Calculating Charge on Capacitors in Parallel | 40 pF & 70 pF [SOLVED]
  • Thread starter Thread starter soccerj17
    Capacitor
The problem involves calculating the charge on capacitors connected in parallel, specifically a 40 pF capacitor charged to 3 kV and an uncharged 70 pF capacitor. The focus is on understanding the behavior of charge and voltage in this configuration.
  • Participants discuss the implications of connecting capacitors in parallel, particularly regarding voltage equality and charge conservation. There is an exploration of how to calculate total charge and voltage after the connection.
Some participants have provided insights into the relationship between the charges and voltages of the capacitors after connection, suggesting that the original charge on the first capacitor must be conserved. Others are working through the calculations and reasoning behind the voltage changes.
There is a noted misunderstanding regarding the use of the initial voltage of the charged capacitor after it is connected to the uncharged capacitor. The discussion highlights the need to consider the total charge and equivalent capacitance after connection.
soccerj17
[SOLVED] capacitor problem
A 40 pF capacitor is charged to 3 kV and then removed from the battery and connected in parallel to an uncharged 70 pF capacitor. What is the new charge on the second capacitor? Answer in units of nC.
pF= 1 F x 10^-12
kV= 1 V x 10^3
nC= 1 C x 10^-9
Q = CV
I thought that because they're connected in parallel that means the voltage is the same across them so I used Q=CV to find charge. For the second capacitor the capacitance is 70 x 10^-12 C and I used the voltage of 3 x 10^3 V. Multiplying them together I got
210 x 10^-9 or 210 nC. I submitted this online to our answer service and it was wrong, and I don't know what I did wrong.
The voltage on capacitor #2 after you connect them is equal to the voltage on capacitor #1 after you connect them, but this is NOT equal to the voltage on capacitor #1 before you connect them, so you can't use the voltage of 3 x 10^3 V
Use the fact that the total charge on both capacitors doesn't change after the connection.
So total charge is the original capacitance (40 pF) times the 3 KV so 120 nC. Then I find voltage by V = Qtotal/Ceq which is C1 + C2 then i use that to find Q by using Q=CV?
Alright i got it!
