Orientation of an object after collision with ground
The discussion revolves around predicting the orientation of a cube after it collides with a concrete surface, considering its initial orientation and the dynamics of its fall. It explores factors influencing the object's behavior during descent and upon impact.
  • Exploratory, Technical explanation, Debate/contested
  • One participant inquires about determining the orientation of an object after it collides with the ground, highlighting the need for initial conditions.
  • Another participant suggests that the object's trajectory, including whether it spins or tumbles during descent, is crucial for understanding its final orientation.
  • A participant specifies that the object is a cube and the ground is concrete, seeking methods to simulate its orientation post-collision.
  • It is noted that as the cube falls, it is likely to tumble randomly, and upon impact, it may bounce, leading to a final orientation that is unpredictable.
Participants express varying views on the factors affecting the final orientation, with no consensus on a definitive method to predict the outcome.
The discussion does not address specific mathematical models or simulations, and assumptions about the initial conditions and environmental factors remain unspecified.
prabhakar157
Hi All,
i am a new bee. if an object is release from certain height with some initial orientation. how do i know, what will be its orientation after collision with the ground.
Thanks and Regards,
K.Prabhakar
To answer that question, you need to know what happened on the way down - spinning, tumbling? Also what is the ground - concrete, mud, grass? I'm sure there are other factors as well.
The object droped is cube, and the groung is made of concrete. how will i simulate its orientation after collision with the ground?
As the cube is falling, ordinarily it will be tumbling in some random manner. Also when it hits the ground it will bounce around. The final orientation will be quite random.
  • · Replies 241 ·
14K
  • · Replies 35 ·
