| New Reply |
Buffer calculations |
Share Thread | Thread Tools |
| Feb27-08, 03:19 PM | #1 |
Buffer calculations
Buffer solution : CH_3COOH (55 mL) + CH_3COONa (45 mL) Ka (CH_3COOH) = 1.76 x 10^-5 Calculate the expected pH of your buffer solution after it has been dilted by making 10 mL of buffer up to 100 mL with deionized water. 2. Relevant equations Ice charts n= c x v c= n/v 3. The attempt at a solution I've calculated the pH for other additions of strong acids and strong bases but I'm not sure how to start this one. Little bit confused... Just the first step would be a great help :) |
| Feb27-08, 03:49 PM | #2 |
You haven't given enough information to start. You need to know something about the concentrations of acetic acid (55 mL?) and acetate (45 mL?).
| Feb28-08, 02:43 PM | #3 |
Sorry, they are both 0.10 M
| Mar4-08, 11:24 AM | #4 |
Buffer calculations
Review the Henderson-Hasselbach equation. Hint: pKa = -log[Ka]
| Dec15-10, 06:05 AM | #5 |
| Dec15-10, 07:11 AM | #6 |
Admin
As chemisttree already wrote: use Henderson-Hasselbalch equation. Start calculating concentrations of both acid and conjugate base. At this stage it will be simple dilution problem.
(in fact you can solve the problem without calculating these concentrations, but I guess explaining the shorter route will only confuse you more) |
| New Reply |
| Thread Tools | |
Similar Threads for: Buffer calculations
| An Introduction to pH and Buffer Solutions Calculations | Other Science Learning Materials | 20 | ||
| ph of (buffer + HCl) | Biology, Chemistry & Other Homework | 1 | ||
| pH of buffer solution | Biology, Chemistry & Other Homework | 2 | ||
| Buffer help. | Chemistry | 1 | ||
| buffer | Biology | 6 | ||
