Forces on a slab of mass Question
  • Thread starter Thread starter bjgawp
    Forces Mass
The discussion centers on a physics problem involving a slab of mass m1 = 40 kg on a frictionless floor and a block m2 = 10 kg on top, with static and kinetic friction coefficients of 0.60 and 0.40, respectively. A horizontal force of 100 N is applied to the block, leading to slipping due to the maximum static friction force of 60 N. As a result, kinetic friction acts on both masses, causing them to accelerate differently until separation occurs.
  • Understanding of Newton's laws of motion
  • Knowledge of static and kinetic friction concepts
  • Ability to calculate forces and accelerations
  • Familiarity with free-body diagrams
  • Study the principles of friction in physics
  • Learn how to draw and analyze free-body diagrams
  • Explore the equations of motion for systems with multiple objects
  • Investigate the effects of different coefficients of friction on motion
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of friction and motion in multi-body systems.
bjgawp
A slab of mass [tex]m_{1} = 40 \mbox{kg}[/tex] rests on a frictionless floor and a block [tex]m_{2} = 10 \mbox{kg}[/tex] rests on top of the mass. Between the block and the slab, the coefficient of static friction is 0.60 and the coefficient of kinetic friction is 0.40. The block ontop of the mass is pulled by a horizontal force of 100 N. What are the resulting accelerations of the block and the slab?
What I'm having trouble is identify the forces. My friend says that with the force being applied on [tex]m_{2}[/tex], there would be friction resisting the motion. Consequently, a force of the same magnitude of the mentioned friction force would occur on [tex]m_{1}in the direction of the applied force[/tex]. How does that work?
The max value of static friction possible between the two is [tex]\mu_sm_2g[/tex] =0.60*10*10=60 N.
Since the applied force is 100 N, definitely there will be slipping between the block and the slab and ultimately, they will get separated.
Until they get separated, Kinetic friction will act and both of them will have different accelerations.
[tex]f_k=\mu_km_2g[/tex]=40 N acting on [tex]m_2[/tex] in the backward direction and on [tex]m_1[/tex] in forward direction.
so [tex]a_1=[/tex]<< solution deleted by berkeman >>
and [tex]a_2=[/tex]<< solution deleted by berkeman >>
_________
I may be wrong.
12K
