| Thread Closed |
a question in basis transformation |
Share Thread | Thread Tools |
| Feb28-08, 05:11 AM | #1 |
when i was told to build the T in the B basis
http://img151.imageshack.us/my.php?image=img8322kt1.jpg are these the right steps??? |
| Feb28-08, 06:07 AM | #2 |
You could check it your self, In terms of the standard basis, Ttr(1, 1, 1)= (3, 3, 7), Ttr(1, 0, 0)= (2, 1, 1), and Ttr(0, 0, 1)= (0, 0, 5). In terms of the B basis, those results would be (3, 3, 7)= a(1, 1, 1,)+ b(1, 0, 0)= c(0, 0, 1)= (a+ b, a, a+ c) so we have a+ b= 3, a= 3, a+ c= 7 which gives a= 3, b= 0, c= 4 or <3, 0, 4> (I am using "< >" for vectors written in the B basis). Similarly, (2, 1, 1) gives a= 1, b= 1, c= 0 or <1, 1, 0> and (0, 0, 5) gives < 0, 0, 5>. If you try to do everything in the "B" basis: multiply your "TB" matrix by <1, 0, 0>, <0, 1, 0>, and <0, 0, 1> you get the first, second, and third columns, respectively. And they are NOT the same.
You error was when you formed the "S-1" transformation matrix: you used the B basis vectors as rows and they should be columns. Use [tex]\left(\begin{array}{ccc} 1 & 1 & 0 \\ 1 & 0 & 0 \\ 1 & 0 & 1\end{array}\right)[/tex] instead and you should be alright. |
| Feb28-08, 06:50 AM | #3 |
i am confused about the vector apeareance
i what form should i put it in the matrix as a row i what form should i put it in the matrix as a column ??? also i was tald that in transformation we put the vectors as rows for example: in this sort of question i was to find the basis of V http://img301.imageshack.us/my.php?i...mg83241re6.jpg first i thought that when a vector is signed as (x,y,z) we flip him verticaly and when its (x) (y) (z) then it should flip it horisontaly but apparently thats not how it works how it works?? how do i write the given vectors in the metrix and in what form and in what cases?? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: a question in basis transformation
| Basis of image of linear transformation | Calculus & Beyond Homework | 3 | ||
| matrix connecting Sz diagonal basis to Sx diag basis | Quantum Physics | 0 | ||
| Basis independent and basis dependent formulation of QM | Advanced Physics Homework | 0 | ||
| Basis for P2 and Linear Transformation | Calculus & Beyond Homework | 3 | ||
| Basis, kernal, image, transformation, etc... (not a hard one!) | Calculus & Beyond Homework | 27 | ||
