Solving Singular Matrix in MATLAB
  • Context: MATLAB
  • Thread starter Thread starter ysun8@uic.edu
    Matrix
The discussion centers on handling singular matrices in MATLAB when attempting to compute their inverse. Users explore the technique of adding a small identity matrix, specifically 0.00005 times the identity matrix, to the diagonal of a singular matrix to facilitate inversion. The example provided illustrates the comparison between directly solving a singular matrix and modifying it with a small identity matrix. The consensus indicates that while this method can yield a result, it is often a workaround for underlying issues in the data or matrix formulation.
  • Understanding of singular matrices in linear algebra
  • Familiarity with MATLAB syntax and operations
  • Knowledge of matrix inversion techniques
  • Basic concepts of numerical stability in computations
  • Research MATLAB's 'pinv' function for computing the pseudoinverse of matrices
  • Learn about regularization techniques for improving matrix conditioning
  • Explore the implications of numerical stability in matrix computations
  • Investigate alternative methods for solving linear equations with singular matrices
Mathematics students, data scientists, and engineers working with MATLAB who need to understand matrix operations and handle singular matrices effectively.
ysun8@uic.edu
singular matrix ?
Hi, guys,
< in MATLAB >
what should i do if i want to get the inverse matrix but it's a singular one? can i just add a very small identity matrix like 0.00005 on the diagnol? will it change the result?
eg:
w0 = S\meandiff
is that the same as
w0 = ( S+0.00005*eye( size( S ) ) )\meandiff
thanks!
Usually if you get a singular matrix, you screwed up somewhere before the inverting step.
cookiemonster
  • · Replies 18 ·
