| Thread Closed |
the equation of a plane perpendicular to a vector and passing through a given point? |
Share Thread | Thread Tools |
| Mar2-08, 01:37 AM | #1 |
Hey guys; im studying calculus and i came across a problem for which the book does not have an answer...
how do i find the equation of a plane perpendicular to vector (2i+3j+4k) and passing though the point (1,2,3) ^^the numbers are some i just made up and no this is not a homework q....in fact i would be glad if any of you can kindly explain to me how this problem can be solved and/or if they can give me the link to some webpage where they have stuff about this thanks :) |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Mar2-08, 01:54 AM | #2 |
The scalar product or dot product, allows you to tell if two vectors are orthogonal or perpendicular among other things. So if you can visualize that the vector [tex] (2, 3, 4)^{T} [/tex] must be orthogonal to every point in the plane then the plane through the origin with normal vector [tex] (2, 3, 4)^{T} [/tex] would be given by the equation [tex] 2x + 3y +4z = 0 [/tex]. This is evident because [tex] (2, 3, 4) \bullet ( x, y, z )^{T} = 2x + 3y +4z = 0 [/tex] implies [tex] (2, 3, 4)^{T} [/tex] is orthogonal to every vector in the plane. Now I leave it to you to figure out how to shift the plane so that it goes through the specified point.
| Mar2-08, 01:56 AM | #3 |
![]() Hint: All lines in that plane will be perpendicular to that vector! So draw the line through the origin, O, parallel to (2i+3j+4k). You want to find the point, F, on that line which is the foot of the perpendicular from (1,2,3), which we'll call P. Call F (2a,3a,4a). Then what is the condition for OF to be perpendicular to FP? |
| Mar2-08, 05:24 AM | #4 |
If you are expected to be able to do a problem like this, you should already know two things:
1) A line in 3 dimensions can be written in parametric equations, x= At+ x0, y= Bt+ y0, z= Ct+ z0, where (x0, y0, z0) is point on the line and [itex]A\vec{i}+ B\vec{j}+ C\vec{k}[/itex] is parallel to the line. 2) A plane can be written as a single equation, A(x- x0)+ B(y- y0)+ C0(z- z0)= 0 where (x0, y0, z0) is a point on the plane and [itex]A\vec{i}+ B\vec{j}+ C\vec{k}[/itex] is perpendicular to the plane. (My mistake, you don't really need to know (1) to do this problem!) |
| Mar2-08, 10:51 AM | #5 |
thank you everyone for your help and suggestions.!
i solved it....in fact im ashamed to see how easy it was... ![]() but even then i might not have found the answer if not for ur help! thanks again Ps: i really should stop doing math till 1 am it took me tens of mins to even get my mind around problems at that time while it took less than a min in the morning.
| Mar2-08, 11:31 AM | #6 |
hehe ran into another prob as i was going through
how do i go about a problem that gives me 3 points of a triangle A,B,C [ A (x1,y1), B(x2,y2),C(x3,y3) ] and asks me to find the interior angles of it? how should i start on this problem?(this is in the section that we use dot product) |
| Mar2-08, 11:39 AM | #7 |
Have you learned that, in additon to the "add the products of the components" formula, [itex]\vec{u}\cdot\vec{v}= ||\vec{u}||||\vec{v}|| cos(\theta)[/itex], where [itex]\theta[/itex] is the angle between [itex]\vec{u}[/itex] and [itex]\vec{v}[/itex]? That should do it easily.
| Mar2-08, 05:09 PM | #8 |
hey , thanks :) i figured it out soon after i posted the q but was not able to delete my q right away cos i was away from the comp. but thanks again.
| Thread Closed |
| Thread Tools | |
Similar Threads for: the equation of a plane perpendicular to a vector and passing through a given point?
| Perpendicular to vector plane | General Math | 1 | ||
| Equation of a Plane with 2 Points and Perpendicular | Calculus & Beyond Homework | 3 | ||
| Prove a vector is perpendicular to a plane? | Introductory Physics Homework | 4 | ||
| Equation of plane perpendicular to another | Calculus & Beyond Homework | 11 | ||
| Finding vector perpendicular to plane | General Math | 6 | ||
