Thread Closed
Oscillator with an inductance with nonzero resistance
Share Thread Thread Tools
Mar2-08, 03:12 PM   #1
Hello,
I need to measure ONLY a change in inductance of a loop (long wire) which has got resistance about 30-200 ohms.
I have tried to build the oscillator according to this schematic : http://ironbark.bendigo.latrobe.edu.au/~rice/lc/
but the problem is it works well with an inductance with almost zero resistance only.
If I connect my loop, it behave wrongly. I guess because of the energy disappation?
Therefore, I need to modify that circuit, or use another another one. Unfortunately, I havent found anything about how to make an oscillator with an resistive inductor.
I read about using a negative resistance circuit but I have no clue how to employ that.
I have also heard about using a transformer (perhaps it is called tapped inductors?).
To summarize my approach:
I only need to detect a change in inductance of a wire loop.
I prefer to have an oscillator with TTL output and to measure therefore the frequency (in a microcontroller)
May I ask you for some hints on that?
Thanks in advance,
Best regards Meereck
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Sensitive bomb detector to rove in search of danger
>> PNNL-developed injection molding process recognized with emerging technologies award
>> How soon could car seats enter the 3-D comfort zone?
Mar3-08, 11:23 AM   #2
Mentor
What is the range of inductance that you are trying to measure, in addition to the 30-200 Ohms of real resistance?
I would probably approach it by driving a signal from a known source impedance, and measuring the in-phase and quadrature components of the divided AC voltage waveform. That will give you values for both the real resistance and the reactive inductive impedance.
Mar3-08, 02:01 PM   #3
Quote by berkeman View Post
thanks for a reply.
The inductance will be about 100-300 microH, its pure resistance will be 30-200Ohm.
Right, but this will probably be quite difficult to measure by a common microcontroller such as a PIC. Would you have any supporting circuit for that?
cheers M.
Thread Closed
Thread Tools
Similar Threads for: Oscillator with an inductance with nonzero resistance
Thread Forum Replies
Every nonzero f(x) in F[x] has a unique monic associate in F[x] Calculus & Beyond Homework 1
What is the theoretical limit to coil inductance over coil resistance? Electrical Engineering 15
Inductance & Resistance in AC Introductory Physics Homework 2
Inductive power transfer + sensing resistance via inductance ? Electrical Engineering 6
Finding Resistance and Inductance of solenoid Introductory Physics Homework 3
