Integration of the function exp(cos(x))
  • Context: Graduate
  • Thread starter Thread starter Gladbo
    Function Integration
The discussion revolves around the integration of the function exp(a*cos(x)) from zero to infinity, with a focus on the use of Bessel functions and the behavior of the integral. Participants explore the nature of the integral, its convergence, and seek assistance with computational tools.
  • Homework-related
  • Anne proposes that exp(a*cos(x)) can be expressed in terms of modified Bessel functions and seeks confirmation on this transformation.
  • One participant argues that the integral diverges, providing a geometric interpretation based on the periodic nature of the function and comparing it to a constant function.
  • Another participant supports the divergence claim by demonstrating that the integral can be expressed as a sum of integrals over periodic intervals, leading to an infinite sum.
  • There is mention of the possibility of results in terms of distributions, particularly regarding the integral of cos(x) over infinite intervals.
  • Several participants express similar issues with the integration limits, specifically from 0 to pi/2, and seek guidance on this variation.
  • References to external resources, such as a book on integrals, are suggested for further assistance.
Participants generally agree on the divergence of the integral when evaluated from zero to infinity, but there is no consensus on the approach to integrate it over different limits or the use of Bessel functions.
Some assumptions regarding the periodicity of the function and the behavior of integrals over infinite intervals are present, but not all mathematical steps or definitions are fully resolved.
Readers interested in advanced integration techniques, the properties of Bessel functions, or those facing similar integration challenges in mathematical or engineering contexts may find this discussion relevant.
Gladbo
Hi. I am trying to integrate the function exp(a*cos(x)) from zero to infinit, where a is a constant. First I've rewritten it to Bessel functions of the first kind like this:
exp(z*cos(x))=BesselI(0,z)+sum(BesselI(v,z)*cos(v*x),v=1..infinit)
where BesselI is the modified Bessel function of the first kind. The last term is the sum over v from 1 to infinit and v is an integer. Is this correct?
Secondly I am trying to get Maple to do the integral using the modified Bessel functions, but I can't get it to work. Can anybody help me? Thank you for your time.
Best regards
Anne
Gladbo, if the integral is the following:
[tex]\int_{0}^{\infty}e^{a cos(x)}dx[/tex]
then I believe it is diverging, meaning it is infinite. This can be shown by the following argument.
step 1
Draw a picture with the function [tex]e^{a cos(x)}[/tex], you will see that is is periodic with period [tex]2\cdot \pi[/tex] and has a lowest value for positive a at [tex]x=\pi[/tex] equal to [tex]e^{-a}[/tex] or for negative a at [tex]x=0[/tex] equal to [tex]e^{-a}[/tex]. This value is always positive.
step 2
Consider the constant function [tex]f(x)=\frac{1}{2}e^{-a}[/tex], valid for all x and lower than the lowest value of the function to be integrated.
step 3
The integral can geometrically be interpreted as the area between the function and the X-axes. A positive value for certain because the function does not go below the X-axes itself. This is also true for the constant function.
step 4
The integral of the constant function from 0 to infinity is now:
[tex]\int_{0}^{\infty}\frac{1}{2}e^{-a}dx= \frac{1}{2}e^{-a}\int_{0}^{\infty}dx= \frac{1}{2}e^{-a}\left[ x \right]_{0}^{\infty}= \infty[/tex]
It is obviously diverging to infinity.
step 5
Because the function you would like to integrate is always larger then the constant one, it's area will also be larger and because the integral for the smaller one is infinity it will certainly be so for the larger one.
Hope this helps, it is not written with firm math, only in words, but I am convinced that the argument is clear.
That method works because of that theorem that goes like "if [itex]f(x) < g(x)[/itex] for all x, then [itex]\int_a^b dx~f(x) < \int_a^b dx~g(x)[/itex]".
You can also show that the integral is divergent as follows: the integrand is indeed [itex]2\pi[/itex] periodic, so if you write it as a sum of integrals over intervals of [itex]2\pi[/itex]:
[tex]\int_0^{\infty}dx~e^{a\cos x} = \sum_{k=0}^{\infty}<br /> \int_{2k\pi}^{2(k+1)\pi}dx~e^{a\cos x}[/tex]
then because you are integrating over an entire period in each case, in each of these integrals you could change variables to get the bounds of the integral to be 0 and [itex]2\pi[/itex]. Because the integrand is 2pi periodic, all of the integrands are the same:
[tex]\int_0^{\infty}dx~e^{a\cos x} = \sum_{k=0}^{\infty}<br /> \int_{0}^{2\pi}dx~e^{a\cos x}[/tex]
The summand now no longer depends on k (and can be evaluated numerically to be about 7.955 for a = 1 - possibly even analytically by contour integration, but it really won't matter in a second), and so what you have is
[tex]\left(\int_{0}^{2\pi}dx~e^{a\cos x}\right)\sum_{k=0}^{\infty}1[/tex]
which diverges.
Of course, perhaps there is a result in terms of distributions, since the integral over cos(x) from -\infty to \infty is a sum of delta functions at +/- 2pi.
Thank you very much both of you!
did you find answer
I have same problem but my limits are from 0 to pi/2 is anybody know how to do this
Smells like Bessel functions. Go to the library and look for a fat russian book, called "table of integrals series and products". It will never let you down.
:smile:
Thank you
Thanks both of you
Udara
