Relativistic quantum mechanics
The discussion revolves around the transition from non-relativistic quantum mechanics to relativistic quantum mechanics, focusing on the differences between the Schrödinger equation and the Klein-Gordon and Dirac equations. Participants explore the implications of symmetry groups, specifically the role of the Lorentz group and the Poincaré group in this context.
  • Some participants note that the Schrödinger equation is not covariant under special relativity transformations, while the Klein-Gordon and Dirac equations are invariant.
  • There is a suggestion that the need to replace the Schrödinger equation arises because relativistic Hamiltonians only commute with generators of the Lorentz group, not with those of the SU(2) group, leading to a lack of rotational invariance.
  • One participant points out that the Schrödinger equation is invariant under rotations but not under boosts, which is a critical issue in relativistic contexts.
  • Another participant emphasizes that the rotational symmetries in a relativistic context are addressed by Lorentz transformations, which are part of the Poincaré group.
  • There is a discussion about the classification of elementary particles based on Casimir operators associated with the Poincaré group, with references to the mass-squared and covariant-spin-squared operators.
  • Some participants clarify that the SO(3,1) group is the Lorentz group, while the Poincaré group includes both the Lorentz transformations and translations in space and time.
Participants express varying levels of understanding and agreement regarding the relationships between the different symmetry groups and their implications for quantum mechanics. Some points remain contested, particularly regarding the nature of the groups and their roles in relativistic contexts.
There are unresolved questions about the definitions and relationships between the various symmetry groups mentioned, as well as the implications of these groups for the equations governing quantum mechanics.
Gigi
I read in wikipedia the following:
'For example, the Schrödinger equation does not keep its written form under the coordinate transformations of special relativity; thus one might say that the Schrödinger equation is not covariant. By contrast, the Klein-Gordon equation and the Dirac equation take the same form in any coordinate frame of special relativity: thus, one might say that these equations are covariant. More properly, one should really say that the Klein-Gordon and Dirac equations are invariant, and that the Schrödinger equation is not, but this is not the dominant usage. '
Thus I have a question on the transition from quantum mechanics to relativistic quantum mechanics:
In non-relativistic quantum mechanics, if the Hamiltonian commutes with J, the angular momentum operator that is a generator of the SU(2) group, it will be rotationally invariant and after a rotation the system will still obey Schroedinger’s equation.
In relativistic quantum mechanics Schroedingers equation is replaced by the Klein Gordon and Dirac equations. Why?
Is it because the corresponding relativistic Hamiltonians in relativistic QM only commute with generators of the Lorentz group, while they do not commute with generators of the SU(2) group---leading to a lack of rotational invariance?
Is that why when we want to combine relativity with quantum mechanics, only a relativistic hamiltonian would work?
Please help---I am so confused :)!
Many thanks!
Well at first glance, the energy in SE is p^2/2m + V
This is non relativistic expression for energy, so here is the first "proof" that SE is not appropative in relativistic considerations of quantum physics.
The SE is invariant under rotations (assuming that it commutes with angular momentum, as you say) but it is NOT invariant under boosts! That's where the trouble comes in.
OK, right that is why we need to replace SE.
One more point here that I still find unclear.
In non-relativistic QM SE is invariant with respect to rotations and translations, if it commutes with the generators of the relevant transformations. The group is SU(2), regarding the rotational symmetry of the non- relativistic Schroedinger equation.
Such a group cannot underline the rotational symmetries of anything relativistic, right?
The rotational symmetries in a relativistic context can only be dealt with Lorentz transforms, which rotational and translational symmetries together by the Poincare group. Right?
(special) relativistic theories have a SO(3,1) symmetry group consisting of rotations and boosts, yes.
Hi...sorry I did not get what you wrote. Is what I said true?
Is the SO(3,1) group the Poincare group? Thanks:)
Gigi said:
In non-relativistic QM SE is invariant with respect to rotations and translations, if it commutes with the generators of the relevant transformations. The group is SU(2), regarding the rotational symmetry of the non-relativistic Schroedinger equation.
SO(3) or SU(2) arise in a relativistic context when one considers the degrees of freedom
of a massive particle at rest. This is actually part of the standard method by which one
classifies what types of elementary particles can exist under the Poincare group.
(This is called "finding the unitary irreducible representations" of the Poincare group.)
The procedure starts by finding all the operators that commute with the Poincare
group generators. These operators are called "Casimir" operators. For the Poincare
algebra, there are only two: the "mass-squared" operator [itex]P^2 = P_0^2 - P_i^2[/itex],
and "covariant-spin-squared" operator [itex]W^2[/itex] which I won't write out in full here.
The eigenvalues of these operators classify the types of elementary particles
(because a particle with one distinct set of these eigenvalues can never have a
different set under Poincare transformations - because the Casimir operators
commute with all Poincare generators).
The Klein-Gordon and Dirac equations are just different ways of writing the
mass-squared Casimir equation above, when represented in particular Hilbert
spaces. For a massive particle, we can find the possible values of spin by
analyzing things in the rest frame, where the only remaining degrees of
freedom are expressed by ordinary rotations, i.e., SO(3) (or its double-cover SU(2)).
Similarly, the Schroedinger equation expresses a Casimir operator from
a different (non-relativistic, i.e., non-Poincare) group.
SO(3,1) is the Lorentz group (also called the homogeneous Lorentz
group). The Poincare group is the Lorentz group, together with
translations in space and time (and is sometimes called the
inhomogeneous Lorentz group).[BTW, this thread should probably be in the quantum physics forum.]
  • · Replies 32 ·
  • · Replies 22 ·
  • · Replies 18 ·
  • · Replies 45 ·
  • · Replies 45 ·
9K
