Signal with AC and DC how to amplify only AC?
  • Thread starter Thread starter DefaultName
    Ac Dc Signal
The discussion focuses on amplifying the AC component of a sine wave signal that has a small AC component in the millivolt range and a DC offset of a few volts. To achieve this, participants recommend using a high-pass filter (HPF) to remove the DC offset, which can be implemented using RC, LC, or op-amp configurations. Following the filtering, a rail-to-rail operational amplifier (op-amp) should be utilized to amplify the AC signal, with a low-noise amplifier like a JFET suggested for optimal performance. Additionally, coupling the signal into the op-amp circuit through a capacitor is advised, with careful selection of capacitor values to set the HPF pole appropriately.
  • Understanding of high-pass filter (HPF) design
  • Familiarity with operational amplifiers (op-amps)
  • Knowledge of AC and DC signal components
  • Experience with low-noise amplifier configurations, specifically JFETs
  • Research high-pass filter design techniques for signal processing
  • Learn about rail-to-rail operational amplifiers and their applications
  • Study the characteristics and benefits of JFET low-noise amplifiers
  • Explore alternatives to PSpice for circuit simulation, focusing on tools that support more than 64 nodes
Electronics engineers, audio signal processors, and anyone involved in signal amplification and filtering techniques.
DefaultName
Hi, I have a sine-wave that has an AC component (that's very small -- mV range) and a DC offset (few volts). Can someone point me in the right direction as far as amplifying only the AC component?
Also, does anyone know an alternative to PSpice Student... I get max'd out at 64 nodes, so I can't any simulation if I exceed that value. Thanks.
filter out the dc component. Take the AC/DC go through a high pass filter (either RC,LC,op-amp depending on cutoff). These will remove the Dc offset.
Then a rail-rail op-amp to amplify the AC signal. Use a low noise amplifier like a JFET.
Yeah, just AC couple the signal into your opamp circuit through a capacitor. Choose the capacitor value to put the HPF pole (the C in combination with the equivalent input R of the opamp circuit) a couple octaves below the AC component's frequency.
  • · Replies 48 ·
9K
  • · Replies 20 ·
  • · Replies 39 ·
