Proving Subspace Membership in R^2 using Vector Dot Product
The discussion revolves around determining whether the set S = { x is in R^2 | x dot a = 0} is a subspace of R^2, where a is the vector (-1,2). Participants are exploring the properties of vector spaces, specifically focusing on closure under addition and scalar multiplication.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants are attempting to prove that the set S is a subspace by showing it contains the zero vector and is closed under addition and scalar multiplication. Questions arise about the correct application of axioms and the logical structure of the proofs being presented.
There is an ongoing exploration of the necessary conditions for S to be a subspace. Some participants have provided partial proofs for closure under addition and scalar multiplication, while others are questioning the clarity and logical flow of the arguments being made. No consensus has been reached yet.
Participants are navigating the requirements for proving subspace membership, including the need to demonstrate closure properties without relying solely on the presence of the zero vector. There is some confusion regarding the notation and terminology used in the proofs.
frasifrasi
The question I am looking at asks,
Let a be the vector (-1,2) in R^2. Is the set S = { x is in R^2 | x dot a = 0}
a subspace?
--> x and a are vectors...
Can anyone explain how to show this?
I was thinking that since the zero vector is in R^2, this must also be a subspace.
Thank you.
Since 0 is in S, you can't conclude that S that S is not a subspace.
Is it a subspace? To aswer this, you must show that S is closed under addition and scalar multiplication. It is pretty direct, try it.
If you run into problem, I can help you.
Oh yes.
Ok, but how would I proceed.
Do i just look at 0 -- k(0) = (k0).
I am not sure how to apply the axiums, can you/someone demonstrate?
Thank you.
I'll do closure under addition for you.
Let x and y be in S. We want to show that x+y is in S also.
well (x+y) dot a = (x dot a) + (y dot a) = 0 + 0 = 0,
so x+y is in S!
(I used the distributivity property of the scalar product)
For the constant,
k(x dot a) = (kx dot a)
k(0) = 0
0 = 0
Is this the proper way?
Thanks for the help.
The exposition is not very logical.
Try again using my template.
"Let x be in S and k be a constant. We want to show..."
Why do you keep looking at 0? Not only does just proving that 0 is in the set not prove it is a subspace, you don't need to prove that 0 is in the set!
You need to prove two things: the set is closed under addition and the set is closed under scalar multiplication.
Suppose u and v are two vectors such that [itex]u\cdot a= 0[/itex] and [itex]v\cdot a= 0[/itex] where a is a fixed vector. Can you prove that u+ v is also in that set- that [itex](u+v)\cdot a= 0[/itex]?
Suppose u is a vector such that [itex]u\cdot a= 0[/tex] and [itex]\alpha[/itex] is any real number. Can you prove that [itex]\alpha[/itex] is also in that set- that [itex]\alpha u\cdot a= 0[/itex]?<br /> <br /> After you have proved the second of those, you don't need to prove 0 is in the set- it follows from the fact that 0v= 0 for any v.[/itex]
so, au dot a = 0
u dot a = 0
so, u(0) = 0.
Is that enough?
thank you for the patience everyone.
frasifrasi said:
so, au dot a = 0
u dot a = 0
so, u(0) = 0.
Is that enough?
I have no idea what you mean by this. You started with a a vector so I don't know what you mean by "au dot a= 0". Did you accidently also use a to mean a number?
What do you mean by u(0)? u is a vector, not a function.
If I try to translate, I get "If ku dot a= 0, then u dot a= 0".
That's exactly the opposite of what I suggested: Show that if u dot a= 0, then ku dot a= 0 for any real number k.
And, of course, you must prove that if u dot a= 0 and u dot v= 0, then (u+ v) dot a= 0.
like the poster above mentioned,
(u+v) dot a = 0
then
(u dot a) + (v dot a) = 0
0 + 0 = 0 so, that is closed under addition.
For scalar multiplication, yes I meant k:
k(u dot a) = k.0 = 0
ku dot a = k.0 = 0
Is this the right way to prove it?
Maybe you understand, but I wouldn't know because your exposition lacks words or at least "<==>" symbols for it to make any sense.
In your proof of scalar multiplication, the critical part of the proof is the fact that ku dot a = k(u dot a). I see you nowhere make that connection explicitely.
