Determining a Basis for P2: Alpha Values
  • Thread starter Thread starter snoggerT
    Basis
The discussion revolves around determining the values of the constant (alpha) for which the set of vectors {1+(alpha)*x^2, 1+x+x^2, 2+x} forms a basis for the vector space P2, which consists of all quadratic polynomials.
  • Participants explore the concept of linear independence and how it relates to the vectors forming a basis. There are attempts to set up systems of equations to analyze the conditions under which the vectors are linearly independent or span the space. Questions arise about specific values of alpha, such as -1, and why other values might not work.
The discussion is ongoing, with participants providing insights into the nature of linear independence and the requirements for a set of vectors to form a basis. Some participants suggest methods for finding the values of alpha, while others seek clarification on the reasoning behind specific steps and values.
There is a recognition that P2 has a dimension of 3, and participants are considering both spanning and independence as criteria for establishing a basis. The discussion includes the potential complexity of the problem and the implications of different values of alpha on the linear independence of the vectors.
snoggerT
Determine all values of the constant (alpha) for which
{1+(alpha)*x^2, 1+x+x^2, 2 +x} is a basis for P2
once again I'm not real sure how to solve this problem. Would I set it up as a system of linear equations? How do you start a problem like this?
Well the basis is the smallest set of vectors that spans a space. It might be easiest to determine all values of alpha such that those 3 vectors are not linearly independent. Consider, for example, alpha = -1.
Can you explain how linear independence works on a vector like that? I know that -1 is the answer, but why wouldn't say -2 or any other negative number?
So you have 3 potential basis vectors: [itex]v_1 = 1+\alpha x^2[/itex], [itex]v_2 = 1+x+x^2[/itex] and [itex]v_3 = 2+x[/itex]
Since there are 3 vectors and you won't find a basis of P2 that has less than 3 members, it suffices to find where [itex]v_1 ,v_2 ,v_3[/itex] are linearly independent. This means that we want to find where [itex]v_1 \neq c_1 v_2 + c_2 v_3[/itex], where [itex]c_1[/itex] and [itex]c_2[/itex] are constants. This means we can formulate 3 equations corresponding to the coefficients on the powers of x for [itex]v_1[/itex] to find where they *are* linearly dependent and not include the corresponding value(s) of [itex]\alpha[/itex] in the solution:
[itex]1 = c_1 + 2c_2[/itex]
[itex]0 = c_1 + c_2[/itex]
[itex]\alpha = c_1[/itex]
Solving for [itex]c_1[/itex] and [itex]c_2[/itex] we find that [itex]c_1 = -1[/itex] and [itex]c_2 = 1[/itex] corresponding to an [itex]\alpha = -1[/itex].
Edit: [tex]\LaTeX[/tex] is showing up a bit weird so maybe check back in a few.
You know, I guess, that P2, the space of all quadratic polynomials, has dimension 3. Knowing that you can show a set of 3 vectors has is a basis by showing either:
1) it spans the space or
2) its vectors are independent.
1) For what values of [itex]\alpha[/itex] do [itex]1+ \alpha x^2[/itex], [itex]1+ x+ x^2[/itex], and 2+ x span all of P2?
Any "vector" in P2 can be written as [itex]a^2+ bx+ c[/itex]. We need to find p, q, r so that [itex]p(1+ \alpha x^2)+ q(1+ x+ x^2)+ r(2+ x)= ax^2+ bx+ c[/itex]. Multiplying out the right side and collecting coefficients of like powers, [itex](p\alpha+ q)x^2+ (q+ r)x+ (p+ q+ 2r)= ax^2+ bc+ c[/itex]. For that to be true for all x, corresp[onding coefficients must be the same: [itex]p\alpha+ q= a, q+ r= b, p+ q+ r= c[/itex]. For what values of [itex]\alpha[/itex] does that systme have a solution? (It might be simpler to ask, "for what values of [itex]\alpha[/itex] does that not have a solution.
2) For what values of [itex]\alpha[/itex] are [itex]1+ \alpha x^2[/itex], [itex]1+ x+ x^2[/itex], and 2+ x independent?
They will be independent if the only way we can have [itex]p(1+ \alpha x^2)+ q(1+ x+ x^2)+ r(2+ x)= 0[/itex] is to have p= q= r= 0. Again, multiplying out the left side and collecting coefficients of like powers, that is [itex](p\alpha+ q)x^2+ (q+ r)x+ (p+ q+ 2r)= 0[/itex]. For that to be true for all x, all coefficients must be 0: [itex]p\alpha+ q= 0, q+ r= 0, p+ q+ r= 0[/itex]. For what values of [itex]\alpha[/itex] is the only solution to that system of equations r= p= q= 0?
Notice that in (2) you have the same system of equations as in 1 except they are equal to 0 instead of the arbitrary numbers a, b, c. Typically, it is easier to prove "independence" rather than "spanning".
And, by the way, this problem has a very simple answer!
- What happened to the 2 in the (p+q+2r) portion of the equation when you set it to 0?
Also, would you solve using a matrix of coefficients? If so, how would you use alpha in it? I understand how you set it up, but not how to solve it.
