What is the final temperature of water when ice is added to it?
  • Thread starter Thread starter SlickNick0013
    Heat Water
The discussion revolves around a thermal equilibrium problem involving the mixing of ice and water. The original poster presents a scenario with 300 kg of water at 70 degrees Celsius and 10 kg of ice at -3 degrees Celsius, seeking to determine the final temperature after the ice is added. The problem involves concepts of heat transfer and latent heat of fusion.
  • The original poster attempts to set up an equation based on heat gained by the ice and heat lost by the water, but expresses confusion over the signs and calculations involved. Some participants suggest reconsidering the signs in the equations, particularly regarding the heat gained by the ice.
Participants are actively engaging with the problem, with some offering alternative approaches and insights into the setup of the equations. There is recognition of the need to clarify the signs in the heat transfer equations, and one participant reflects on their understanding of the relationship between heat gained and lost.
Participants note the importance of correctly interpreting the heat transfer equations, particularly in terms of the signs used for heat gained and lost. There is an acknowledgment of the complexities involved in thermal equilibrium problems.
SlickNick0013
1. You have a tub of water that you are placing ice into. There is 300kg of water at 70 degrees celsius. You add 10kg of ice at -3 degrees C. What is the final temperature of the water? The latent heat of fusion for water is 33.5 x 10^4 j/kg
I have worked out the best I can the problem as I understand it and I come up with an answer that does not quite make sense O.o
2.
Q= heat
Qgained = Qlost;
therefore
Qgained - Qlost = 0
3. ice is gaining ...water is losing
mc(changeintemp) + mLfusion - mc(ChangeinTemp) = 0
mc(start - final) + mLfusion - mc(start - final)=0
mc(-3 - final) + mLfusion - mc(70-final)=0
((10*4186(-3-final)) + 33.5x10^4) - (300*4186(70-final))=0
(41,860(-3-final) + 33.5 *10^4) - (1,255,800(70-final))=0
-125,580 - 41,860final +33.5*10^4 - (87,906,000 - 1,255,800final)=0
-125,580 - 41,860final + 335,000 - 87,906,000 + 1,255,800final = 0
-41,860final + 1,255,800final + 209,420 - 87,906,000= 0
-41,860final + 1,255,800final -87,696,580 = 0
-41,860final + 1,255,800final = 87,696,580
final(-41,860 + 1,255,800) = 87,696,580
final(1,213,940) = 87,696,580
final = 87,696,580 / 1,213,940 = 72.241 degrees C??
if the -41,860 was positive it came to a plausable answer. Now, I've checked over and and over and I don't understand where my error is but... 87,696,580/ (41,860 + 1,255,800) = 67.5 degrees C. Is one of my signs backwards or did i setup the problem incorrectly. Thanks for any help.
/bump
Halp...I'll <3 u long time
Seems like it should be mc(-3 + final).
This is the heat gained by the ice. The final temperature will be positive, so as you have it now, heat gained by ice comes out negative. Change that minus to a plus, and heat gained by ice becomes positive, like it should be.
This is an alternative way to do it I suppose: I can't promise that it will work, but it might give you the correct answer. I am not an expert or anything but my last chapter was dealing with Thermodynamics and I had a lot of problems like this.
Q = CMT
Heat = heat capacity * mass * (Tfinal - Tinitial)
Waters heat capacity is 4.184 and ice is 2.092
4.184J/cal * 300kg (x-70C) = 2.092J/cal * 10kg (x-(-3))
Good luck, and also I agree with turning it positive.
Edit: I ran my calcs and I came up with around 68-69C.
I understand the error now... in the equation Qlost = Qgained it isn't actually Qlost = Qgained but rather the magnitude of difference of Qlost and Qgained is equal I.E.
|Qlost| = |Qgained| which sounds dumb because obviously one of them is going to be negative(losing heat) and one positive(gaining heat) but it just never clicked.
So, in bringing one of them to the other side I needed to set up so they both ended up positive (or take their abs value). So for lost it's (InitalT - finalT) but for gained it's (finalT - initialT). I knew there was an error but I just could not understand why in actuallity it is what it is...now I do, thanks!
