Horsehoe Bats, Insects, Speed and the Doppler Effect
The discussion revolves around the application of the Doppler effect in the context of horseshoe bats (genus Rhinolophus) determining the speed of insects based on sound frequency changes. The original poster presents a problem involving sound frequencies emitted and received by a bat in flight, aiming to calculate the speed of an insect based on these frequencies and the bat's speed.
  • The original poster attempts to apply Doppler shift equations to find the speed of the insect but expresses uncertainty about their calculations. Some participants question the definitions and signs of the variables used in the equations, suggesting potential errors in the setup. Others explore the implications of substituting one equation into another and the resulting dependencies on the variables.
The discussion is ongoing, with participants providing insights and clarifications about the parameters involved. There is a recognition of the complexity in the equations and the need for careful consideration of the signs of the variables. Some participants have offered guidance on interpreting the equations, but no consensus has been reached regarding the final answer.
Participants note the importance of correctly identifying the roles of the variables in the equations, particularly in relation to the movement of the bat and the insect. There is mention of a textbook example that may influence the understanding of the problem setup.
TFM
[SOLVED] Horsehoe Bats, Insects, Speed... and the Doppler Effect
Horseshoe bats (genus Rhinolophus) emit sounds from their nostrils, then listen to the frequency of the sound reflected from their prey to determine the prey's speed. (The "horseshoe" that gives the bat its name is a depression around the nostrils that acts like a focusing mirror, so that the bat emits sound in a narrow beam like a flashlight.) A Rhinolophus flying at speed [tex]v_b_a_t[/tex] emits sound of frequency [tex]f_b_a_t[/tex] ; the sound it hears reflected from an insect flying toward it has a higher frequency [tex]f_r_e_f_c[/tex] .
If the bat emits a sound at a frequency of 80.8 kHz and hears it reflected at a frequency of 83.1 kHz while traveling at a speed of 4.2 m/s, calculate the speed of the insect.
Use 344 m/s for the speed of sound in air. Express your answer using two significant figures.
Doppler Shift Equations:
[tex]f_I = (\frac{v + v_I}{v + v_b_a_t})f_b_a_t[/tex]
[tex]f_r_e_f = (\frac{v + v_b_a_t}{v + v_I})f_I[/tex]
the answer I got by using these two equations was 10.45, got via:
firstly, I inserted the values into the top equation, to get [tex]f_I[/tex] in terms of [tex]v_I[/tex] :
[tex]f_I = (\frac{344 + v_I}{344 + (-4.2)})80.8[/tex]
[tex]f_I = (\frac{344 + v_I}{339.8})80.8[/tex]
[tex]f_I = (\frac{344}{339.8} + \frac{v_I}{339.8})80.8[/tex]
[tex]f_I = (81.7987 + \frac{80.8v_I}{339.8})[/tex]
[tex]f_I = (81.7987 + 0.2672v_I)[/tex]
I then rearranged the second equation:
[tex]83.1 = (\frac{344 + 4.2}{344 + v_I})f_I[/tex]
[tex]83.1 = (\frac{348.2}{344 + v_I})f_I[/tex]
[tex]83.1*(344 + v_I) = 348.2f_I[/tex]
[tex]28586.4 + 83.1v_I) = 348.2f_I[/tex]
Now inserting [tex]f_I[/tex]:
[tex]28586.4 + 83.1v_I) = 348.2((81.7987 + 0.2672v_I))[/tex]
[tex]28586.4 + 83.1v_I) = ((28482.31 + 93.045v_I))[/tex]
[tex]104.0909 = 9.94v_I[/tex]
Giving the Insects speed as 10.46
Any ideas where I have gone wrong?
TFM
Any ideas where I may have gone wrong?
TFM
It would help a lot if you would tell what each parameter means. I assume that "v" is the speed of sound. You appear to have two equations:
[tex]f_I= \frac{v+ v_i}{v- v_{bat}}f_{bat}[/tex]
and
[tex]f_{ref}= \frac{v+ v_{bat}}{v+ v_I}f_I[/tex]
If you just go ahead replace [itex]f_I[/itex] in the second equation by the first you get
[tex]f_{ref}=\frac{v+ v_{bat}}{v- v{bat}}f_{bat}[/tex]
which has NO dependence on [itex]v_I[/itex]!
Perhaps both [itex]v_{bat}[/itex] and [itex]v_I[/itex] should be positive in one equation and negative in the other.
Sorry, that is rather sill of me.
[tex]v[/tex] speed of sound
[tex]v_I[/tex] Speed of Insect
[tex]v_b_a_t[/tex] speed of bat
[tex]f_b_a_t[/tex] frequency emitted by bat
[tex]f_I[/tex] frequency heard by Insect
[tex]f_r_e_f[/tex] frequency reflect back and heard by bat
as fir the speed, in the book, it has a car and a wall, and the speed of the car for the emitted wave is negative, the speed when the wave is headed back is positive. the speed of the wall is zero, so I just took the insect speed parts from the relevant equations for moving source/moving listener.
Does this help?
TFM
I never realized that the latex had taken over the actual question. The question is:
TFM
Using:
[tex]f_I = (\frac{v+v_I}{v-v_b_a_t})f_b_a_t[/tex]
and
(This should be f reflected = ...) => [tex]f_r_e_f = (\frac{v+v_b_a_t}{v-v_I})f_I[/tex]
and rearranging similarly to what I did in the first post, I now get a small answer of:
0.6274 (?)
Does this look right?
TFM
It is the right answer. The book gives another equation, whch returns the same value, and it is correct!
Thanks HallsofIvy,
TFM
9K
  • · Replies 16 ·
