Thread Closed
Work/force/kinematics slingshot problem
Share Thread Thread Tools
Mar5-08, 04:07 PM   #1
[b]1. An average force of 8.2 newtons is used to pull a .4 kg rock, stretching a sling shot 43 centimeters. The rock is shot downward from a bridge 18 meters above a stream. What will be the velocity of the rock just before it hits the water? How much time will it take to hit the water.
2. Relevant equations
[b]3. I just want to know if the spring/work equation, .5k(x)squared=w applies to the slingshot, and would stretching it by 43 CM = the x part of the equation? I don't know what to do once I get work. How do i get the velocity of the rock? I know A after shot would be 9.8, d is 18, but is final Velocity 0?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Mar5-08, 04:28 PM   #2
Recognitions:
Homework Helper Homework Help
Quote by Shadowsol View Post
It does apply, and yes. The spring PE is converted to KE. That's how you get the velocity. Final velocity nowhere is zero.
Mar6-08, 04:16 PM   #3
Ok, so I put in the force*the distance it was pulled back to get the potential sling shot energy. I than set that equal to the KE equation and got V. Than I simply used that V as V0, used 9.8 as A, and 18 m as D, than solved for V1. Is this correct?
Mar7-08, 01:46 AM   #4
Recognitions:
Absolutely. You find the time using the same kinematics.
Thread Closed
Thread Tools
Similar Threads for: Work/force/kinematics slingshot problem
Thread Forum Replies
Frictional Force/Kinematics Problem Introductory Physics Homework 13
Spring/Incline plane kinematics/work problem Introductory Physics Homework 2
Centrigugal force slingshot,the projectile is shot by the normal General Physics 4
need help w/Speed of a Slingshot problem Introductory Physics Homework 1
kinematics: force along x-axis problem Introductory Physics Homework 3
