Magnetic Fields and Current experiment
The discussion focuses on calculating the maximum allowable current in an electric cable located 1.00m from an experiment measuring the Earth's magnetic field, aiming for an accuracy of +/- 1.0%. The relevant equation used is B = μI / (2πr), where B represents the magnetic field, μ is the permeability of free space, I is the current, and r is the distance from the wire. The conclusion drawn is that the maximum allowable current is 2.5A, ensuring that the magnetic field produced by the cable does not exceed 1% of the Earth's magnetic field.
  • Understanding of magnetic fields and their calculations
  • Familiarity with the equation B = μI / (2πr)
  • Knowledge of the Earth's magnetic field strength
  • Basic algebra for solving equations
  • Research the Earth's magnetic field strength in various locations
  • Learn about the permeability of free space (μ) and its significance
  • Explore the effects of current on magnetic fields in different configurations
  • Study the implications of measurement accuracy in experimental physics
Students and educators in physics, particularly those involved in experiments related to electromagnetism and magnetic field measurements.
mer584
I put this in the intro forum about 3-4 hours ago and no one answered, can anyone here help?
1. Homework Statement
An experiment on the Earth's magnetic field is being carried out 1.00m from an electric cable. What is the maximum allowable current in the cable if the experiment is to be accurate to +/- 1.0%
2. Homework Equations
B= uI/2(pi)r
B is proportional to I/R where B is the magnetic field and pi=3.14
F=IBI where this is I one and I two.
3. The Attempt at a Solution
I'm not really sure to do without any numbers. Is there a way to find B so you can then use the first formula I listed to find I using R=1m.
Is there a way to express B in terms of that percentage? The answer is 2.5A
B= uI/2(pi)r
I went ahead and deleted your post in Intro Physics, since you prefer the thread here. Keep in mind that it's Friday afternoon/evening for much of the world, so expecting replies in a couple hours may not be realistic.
Now, on to your problem. What is the magnitude and direction of the Earth's magnetic field (at least on the surface of the Earth on the main continents, where presumably this experiment is being carried out)? If you want to be able to measure that to within 1%, then you want the magnetic field from the nearby wire to be about 0.01 of the Earth's magnetic field. That tells you (via the equation that you mention for the magnetic field surrounding a current-carrying wire) how much current you can tolerate in the nearby cable.
O.K. I see it now. Thank you.
