Degenerate Perturbation Theory Question
This discussion revolves around the application of perturbation theory to a two-dimensional infinitely deep square well, specifically examining the perturbation caused by a potential of the form V(x)=α(x²+y²). The original poster seeks to determine the first-order correction to the energy of the first excited states, characterized by the quantum numbers (1,2) and (2,1).
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster calculates integrals related to the perturbation and questions whether the perturbation lifts the degeneracy of the states. Some participants express skepticism about the zero result of one integral and discuss the implications of orthogonality in the context of the perturbation.
Participants are actively engaging with the calculations presented, questioning assumptions about the integrals and discussing the implications of the results. There is an acknowledgment that the perturbation may not lift the degeneracy, but no consensus has been reached.
There are discussions regarding the limits of integration and the setup of the problem, with some participants suggesting that the original poster may have misinterpreted the bounds of the well.
T-7
Hello,
This is a question on perturbation theory - which I am trying to apply to the following example.
The two-dimensional infinitely deep square well (with sides at x=0,a; y=0,a) is perturbed by the potential V(x)=[tex]\alpha(x^{2}+y^{2})[/tex]. What is the first-order correction to the energy of the first excited states (that is, those with quantum numbers (1,2), (2,1))?
I have calculated [tex]\langle\left\right 1,2^{(0)}|\widehat{V}|2,1^{(0)} \rangle[/tex]. In Maple this is:
> value( Doubleint( (2/a)*sin(Pi*x/a)*sin(2*Pi*y/a)*(x^2+y^2)*(2/a)*sin(2*Pi*x/a)*sin(Pi*y/a) ,x=0...a,y=0...a) );
which is zero.
I have calculated
[tex]\langle\left\right 1,2^{(0)}|\widehat{V}|1,2^{(0)} \rangle[/tex]. In Maple this is:
value( alpha*Doubleint(4*sin(Pi*x/a)*sin(2*Pi*y/a)*(x^2+y^2)*sin(Pi*x/a)*sin(2*Pi*y/a),x=0..a,y=0..a) )
which is
[tex]\alpha a^{2}\left( \frac{16\pi^{2}-15}{24 \pi^{2}} \right)[/tex]
Am I to conclude from this that the perturbation, in *this* case, does not lift the degeneracy, and that the first order correction to the energy is the same for both states, and is given above?
I had expected to form a matrix, work out its eigenvalues and eigenvectors, use that to construct a new basis etc. But the matrix I would form from the above would already be diagonalised, with a repeated eigenvalue of 1.
I'd appreciate some speedy words of wisdom :-)
Thanks folks
I don't see how your <12|V|21> integral could be zero.
Why not?
The integral of sin(x) sin(2x) x^2 is zero since it's odd with respect to the center of the well and the integral sin(x) sin(2x) y^2 is obviously zero.
EDIT: Oops, I was wrong on this since I was thinking about a well going from -a/2 to a/2,
T-7 said:
Hello,
which is zero.
I have calculated
which is
Thanks folks
It does seem to me that you are right. Here the degeneracy is not lifted.
Did you leave out the x^2+y^2 in the integrals from 0 to a?
If you are integrating from -a/2 to +a/2, then change your question.
Hi,
I have done the integral on paper and on Maple. On Maple I put:
The (x^2+y^2) is there, as you can see. The result is zero (which is what I also get using paper and pen).
Since the well is defined from 0 to a, I have used those as the limits of the integrals.
|1> and |2> are orthogonal. So,
<1,2|x^2 + y^2 |2,1>
=<1|x^2|2><2|1> + <1|2><2|y^2|1>
= 0 + 0
= 0
OP: It's quite reasonable that the potential doesn't lift the degeneracy since the unperturbed potential (the length of the box) is the same in x and y and the perturbation also treats x and y on equal footing.
= 0 + 0
= 0
That's right! Sorry to have said the opposite. I didn't notice the x^2 did not enter the y integral.
Ah yes..Ok, my mistake too. Of course, the x integral does not give zero but the y part will give zero so the whole thing is zero. My mistake too...
Thanks for your thoughts folks. Much appreciated. :-)
