Thread Closed
Fourier Transform (Another question):
Share Thread Thread Tools
Mar8-08, 10:47 AM   #1
I need to find the fourier transform of f(x) which is given by the equation:
[tex]-\frac{d^2f(x)}{dx^2}+\frac{1}{a^3}\int_{-\infty}^{\infty}dx'exp(-\lambda|x-x'|)f(x')=\frac{b}{a^2}exp(-\lambda|x|)[/tex]
ofcourse Iv'e taken the fourier tarnsform of both sides, but I don't see how to calcualte the fourier tranform of the integral in the above equation, I feel I need to use the definition of dirac's delta function, but don't see how to do this, any ideas, hints?
thanks in advance.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Mar8-08, 11:28 AM   #2
Without doing the fourier transform, it looks to me like you'll need to use the property that [itex]\delta(x'-x)f(x')=f(x)[/itex]. Just note which of x and x' is actually a variable for integration and which is the "constant" inside the integration. Use Parseval's Theorem.
Mar8-08, 11:32 AM   #3
I'm not sure it's correct I got that the F.T of the integral without the constant 1/a^3 is:
2pi*f(0)*e^(a-\lambda|x|), is this correct?
Mar8-08, 12:59 PM   #4
Well actually disregard my previous advice, sorry! Note that the integral is equivalent to [itex]e^{-\lambda |x|} \ast f(x)[/itex] where the operator is convolution. In the frequency domain, this becomes multiplication. Now you simply need to know [itex]e^{-\lambda |x|} \Leftrightarrow \frac{2\lambda}{\lambda^2 + \omega^2} [/itex] which is actually the same answer as you'd arrive by from what I previously said, but in much less time.
Mar8-08, 01:26 PM   #5
so using convolution you say, ok I'll try it, thanks.
Thread Closed
Thread Tools
Similar Threads for: Fourier Transform (Another question):
Thread Forum Replies
Fourier Transform Question Engineering, Comp Sci, & Technology Homework 1
Fourier Transform Question Calculus & Beyond Homework 0
Fourier Transform question General Physics 3
Fourier Series / Fourier Transform Question Electrical Engineering 6
The difference between Fourier Series, Fourier Transform and Laplace Transform General Physics 1
