Classification Theorem of Surfaces
The discussion revolves around the Classification Theorem of Surfaces, focusing on the implications and understanding of the theorem in the context of topology and geometry. Participants explore various aspects of closed surfaces, homeomorphism, and the classification of surfaces, including both topological and complex surfaces.
  • Some participants clarify that every closed surface is homeomorphic to a sphere, the connected sum of g tori, or the connected sum of g projective planes.
  • One participant notes that closed surfaces refer to closed 2-dimensional manifolds that can be embedded in R^n.
  • Another participant points out an error in reasoning related to the invariance of dimensions, specifically regarding the relationship between S^n and R^{n+1}.
  • Concerns are raised about the compactness of surfaces, with examples given that highlight differences between compact and non-compact spaces.
  • Some participants express assumptions regarding the classification of complex surfaces based on Kodaira dimension, listing various types of surfaces such as rational and K3 surfaces.
  • One participant shares a basic theorem regarding topological 2-manifolds and mentions a proof involving simplexes and free groups, suggesting a more advanced proof might exist via homology.
  • Another participant introduces a Morse theory proof for oriented surfaces, discussing the arrangement of critical points on the surface.
Participants express differing views on the implications and interpretations of the Classification Theorem of Surfaces. There is no consensus on the specific applications or proofs related to the theorem, and multiple competing perspectives are present regarding the classification of surfaces.
Some limitations in understanding arise from missing assumptions and the complexity of definitions related to surfaces. The discussion includes unresolved mathematical steps and varying interpretations of the theorem's implications.
Tchakra
I am having difficulties grasping the consequences of this theorem, would really appreciate a little enlightenment.
A: Well, the statement of the theorem is clear, that Every closed Surface is homeomorphic to:
1) a sphere,
2) the connected sum of g tori
3) or the connected sum of g Projective plane.
B: Closed surface means Every closed 2 dimensional manifold that is embeddable in [tex]R^n[/tex]. So [tex]S^3[/tex] or in fact [tex]S^n[/tex] is homeomorphic to one of the above.
C: Another point is that [tex]S^n \cong R^{n+1}[/tex]
So by transitivity we get [tex]R^4 \cong S^3 \cong S^2 \cong R^3[/tex], which is false by the invariance of dimensions.
Given A,B and C i come to this conclusion which i know to be wrong, so can someone explain to me where i went wrong.
The only conscious leap i have made is B, which i haven't read from any book, but given the definition i don't see why it should be otherwise.
I just realized my mistake, my third point is wrong. The Euler characteristic is different ...
I was wondering why you would even think so! S1, a circle, is obviously not homeomorphic to R2, a plane. S2, the surface of a a sphere is not homeomorphic to R3. In both cases, the first is compact and the second isn't.
I had a perfectly valid reason at the time :-p, f(x)= x/|x| , if you discount to consider the point x=0 which i didn't.
Also, S^3 is clearly not a 2 dimensional manifold.
i assumed this was about classifying complex surfaces, by kodaira dimension.
i.e. rational, ruled surfaces, elliptic surfaces, abelian surfaces, K3 surfaces, surfaces of general type.
That's what I thought about too when I saw the title. :smile:
I only know the basic theorem:
every topological 2-manifold (surface by some authors) is homeomorphic to the connected sum of either a sphere or some finite combination of tori and projective planes. I also only know the basic proof which involves building your surface from simplexes, noticing that by labeling the edges you can represent each surface as an element in some free group, and then showing that each of these elements reduce to either 1 or some finite "product" of the element which corresponds to tori and the element which corresponds to the projective plane. Seems like there should be a more advanced proof via homology though.
for oriented surfaces at least, i like the morse theory proof, namely there is a smooth function on the surface that has a finite number of non degenerate critical points, which can be arranged to be one max, one min, and 2g saddle points.
(all surfaces have a smooth structure.)
  • · Replies 39 ·
  • · Replies 17 ·
