How do you prove immersion? (Basic Riemannian Geometry)
The discussion focuses on proving that a mapping is an immersion in the context of Basic Riemannian Geometry. The specific mapping under consideration is defined by the function F: R^3 --> R^4, where F(x,y,z) = (x^2-y^2, xy, xz, yz). The user seeks guidance on how to demonstrate that the differential mapping dep: TpM --> Te(p)N is injective for all points p in the manifold M. Key insights include the necessity of computing the derivative of the mapping and verifying its rank to establish immersion.
  • Understanding of differentiable manifolds and mappings
  • Knowledge of the definition and properties of immersions
  • Familiarity with differential calculus in multiple dimensions
  • Concept of rank and nullity in linear algebra
  • Learn how to compute the derivative of a mapping in Riemannian Geometry
  • Study the rank-nullity theorem and its application to immersion proofs
  • Explore examples of immersions and non-immersions in differentiable manifolds
  • Investigate the implications of the Dimension theorem in the context of mappings
Students and researchers in mathematics, particularly those studying differential geometry, manifold theory, and applications of immersion in Riemannian Geometry.
b0it0i
the question i have is more of a conceptual question, i have no idea how to prove that a mapping would be an immersion. thus i have no clue how to start the assigned problem
here's the specific problem:
prove that (e~) is an immersion : note (e~ means phi tilda)
Let F: R^3--> R^4 be given by
F(x,y,z) = (x^2-y^2, xy, xz, yz), where (x,y,z) = p element of R^3
Let S^2 subset of R^3 be the unit sphere with the origin 0 element of R^3
Observe that the restriction (phi) e = F | S^2 is such that e(p) = e(-p),
and consider the mapping (phi tilda) e~: P^2(R) --> R^4 given by
e~( [p] ) = e(p)
where [p] is the equivalence class of p. [p] = {p, -p}
note that: P^2(R) means the real projective plane
Definition of immersion: Let M^m and N^n be differentiable manifolds. A differentiable mapping
e: M --> N is said to be an immersion if
(dep = differential of e at p)
dep: TpM --> Te(p)N is injective for all p element of M
def of dep: Let M and N be differentiable manifolds. and let e: M --> N be a differentiable mapping. For every p element of M, and for each v element of TpM,
choose a differentiable curve a:(-E,E) --> M with a(0) = p, a'(0) = v.
Take B = e o a (phi compose a). The mapping
dep: TpM --> Te(p)N
given by dep(v) = B'(0)
I thought you would need to use the definition of immersion, stated above, to show that a mapping is indeed an immersion. So i must show that
dep: TpM --> Te(p)N is injective for all p element of M.
HOWEVER: the examples in the book do not use this definition, or it skips over major steps, when they show that certain mappings are / aren't immersions.
for example:
1) The curve a: R--> R^2 given by
a(t) = (t, |t|) is not differentiable at t=0. a is not an immersion
2) The curve a(t) = (t^3 - 4t, t^2 - 4) is an immersion
a: R --> R^2
Do i need to use the definition of dep to find this curve "a".
Take B = e o a (phi compose a). The mapping dep: TpM --> Te(p)N given by
dep(v) = B'(0)
can anyone clarify the concept / process to show how to prove a mapping is an immersion. I don't want the answer to this problem, just some guidance. By the way, this problem is not for any points, it's just a suggested problem.
Well, it's pretty clear the function is differentiable (and so doesn't fail to be an immersion for the reason your first example does), so one way to proceed would be to compute its derivative and show its rank is 2.
I see, and you made that conclusion because of the Dimension theorem?
a linear function is 1-1 iff it's nullity is 0
iff rank = dim (P^2(R))
