Register to reply
Basic Circuit Problems - KVL and KCL
by steven10137
Tags: basic, circuit
Share this thread:
steven10137
#1
Mar9-08, 12:21 AM
P: 118
Find [tex]R_2[/tex] in the circuit below.
2. Relevant equations
Kirchoff's Current Law:
[tex]\sum {I_{IN} } = \sum {I_{OUT} }[/tex]
Kirchoff's Voltage Law:
[tex]\sum {V = 0}[/tex]
3. The attempt at a solution
Using KCL for the node joining the 8ohm resistor, R2 and the 1 ohm resistor:
[tex]i_1 = i_2 + 2[/tex]
Now using KVL for the shortest route down the 1 ohm resistor from the voltage source.
[tex] - 10 + 8i_1 + 2 = 0\; \Rightarrow \;i_1 = 1\;A[/tex]
From the first equation;
[tex]i_2 = i_1 - 2 = 1 - 2 = - 1\;A[/tex]
Until this point, everything seems logical, and I think it is right.
Now in order to solve for [tex]R_2[/tex] I must now use [tex]V = IR[/tex] correct?
But, am I right in saying that because the voltage is flowing in the same direction and has changed by 2V, that the potential difference = 2V. Therefore [tex]R_2 = \frac{2}{{ - 1}} = - 2\;\Omega[/tex].
Resistance can't be negative though can it?
Can someone explain the situation in simple terms or what laws govern this?
I'm happy to read further if some people can give me some hints in the right direction.
Cheers
Steven.
Phys.Org News Partner Science news on Phys.org
Scientists develop 'electronic nose' for rapid detection of C. diff infection
Why plants in the office make us more productive
Tesla Motors dealing as states play factory poker
CEL
#2
Mar9-08, 05:55 AM
P: 639
What is the voltage across the 1 ohm resistor?
R2 has one side connected with the 1 ohm resistor and the other connected to the 12V source. What is the voltage drop across it?
steven10137
#3
Mar9-08, 06:22 AM
P: 118
Quote Quote by CEL View Post
V=IR = (2)(1) = 2V
The Voltage drop is therefore 12 - 2 = 10V?
CEL
#4
Mar9-08, 07:24 AM
P: 639
Knowing the voltage drop and the current through R2, you can calculate its value.
steven10137
#5
Mar10-08, 03:21 AM
P: 118
excellent cheers mate.
I was also shown another method today which involved more dependability on the sign conventions, but is more politically correct, yet yields the same result.
samhilton090
#6
Sep19-09, 10:54 PM
P: 1
resistance can never be negative
but it coming negative because direction of current taken is opposite
you can call this beauty of kvl and kcl
rjhuntington
#7
Jul20-10, 06:37 AM
P: 1
Quote Quote by steven10137 View Post
Of course the resistance cannot be negative, but the problem is resolved by realizing the direction of the current is into the common node of the resistors, not away from it.
Register to reply
Related Discussions
Very Basic Circuit Question Electrical Engineering 10
Basic Circuit question Electrical Engineering 6
Circuit Theory - Basic Engineering, Comp Sci, & Technology Homework 5
Basic Circuit Analysis Engineering, Comp Sci, & Technology Homework 4
Basic Circuit analysis Electrical Engineering 1
