Producing Ethanol: The Role of Lewis Structures in Chemical Bonding
  • Thread starter Thread starter bjoyful
    Ethanol
The discussion revolves around the production of ethanol through the reaction of water vapor with ethylene, focusing on the use of Lewis structures to analyze chemical bonding and the mechanisms involved in the reaction. Participants explore concepts related to chemical reactions, mechanisms, and the specific bonds broken during the formation of ethanol.
  • Homework-related
  • One participant presents a homework problem involving the reaction of ethylene and water to produce ethanol and asks whether all chemical bonds need to be broken to form the product.
  • Another participant asserts that not all bonds need to be broken, prompting a question about the mechanism of the reaction.
  • A participant describes the reaction as an electrophilic addition, explaining the role of the pi bond in ethylene and the polar nature of water, leading to the formation of a carbocation.
  • It is noted that only the pi bond of the C=C and the O-H bond from water are broken during the reaction to form ethanol.
  • Another participant suggests a simpler approach of comparing Lewis structures to identify which bonds change during the reaction.
  • Additional contributions mention alternative methods of producing ethanol, such as fermentation of glucose with yeast, and the conditions required for the reaction of ethene and water to produce ethanol under specific temperature and pressure conditions.
Participants generally agree that not all bonds need to be broken to form ethanol, specifically identifying the C=C and O-H bonds as the ones that are broken. However, there is some uncertainty regarding the mechanisms and approaches to understanding the reaction.
Participants express varying levels of familiarity with the chemistry involved, indicating that some assumptions about prior knowledge may not hold for all contributors. The discussion also highlights different approaches to understanding the reaction, which may depend on individual learning preferences.
This discussion may be useful for students studying organic chemistry, particularly those interested in reaction mechanisms and the application of Lewis structures in understanding chemical bonding.
bjoyful
producing ethanol...
One way to produce ethanol for use as a gasoline additive is the reaction of water vapor with ethylene: H2C=CH2 + H2O ----> CH2CH2OH Rewrite this equation on a piece of paper using Lewis structures, and use those structures to answer the following question: Was it necessary to break all of the chemical bonds in the reactants in order to form the product, ethanol? Explain your answer.
I rewote the equation on a piece of paper with the Lewis structures H2C= H-C-H, CH2= H-C-H, H2O= H-O-H, CH2= H-C-H, CH2= H-C-H, OH=O-H. I also wrote for ethanol: H-C=O=C-H (with single bonds of H coming off of the C on both top and bottom, due to format limitations, I can't right it..:( Is this right? Was it necessary to break all of the chemical bonds to form reactants?
Thanks!
errmm no you don't have to break all the bonds...
do you know the mechanism for this reaction?
I am not sure about the mechanism for this reaction...I am totally new at this chemistry stuff! Thanks for your help:)
this is called electrophilic addition reaction. basically electrophiles are species which are attracted by negatively charged species. so in ethene there is a pi bond in the C=C.
now, in water, there is oxygen atom which is very electronegative. it tends to pull the shared pair of electron across the O - H bond towards itself. hence, it gets a partial negative charge. the hydrogen consequently gets a partial positive charge. this is why water is polar.
when water molecules approach the pi bond, the pi electrons further repel the shared pair of electron in the O - H bond causing heterolysis. H+ and OH- are formed.
the H+ is attracted towards the pi bond(consisting of electrons). the pi electrons (in the pi bond) forms a covalent bond with the H+.
now, the ethene molecule becomes CH3C(+)H2. this is known as a carbocation. the carbon has a positive charge.
remember the OH- ion? it then forms a covalent bond with the carbocation(C+). ethanol is finally formed.
this is the simplest example of electrophilic addition reaction.
so, the only bonds broken are the pi bond of the C=C (not the sigma bond) and O - H from water.i hope this is your level of chemistry...
So I don't have to break all the bonds to form ethanol, just the C=C and the O-H?
another much more simple approach was to compare the lewis structures of both ethene and ethanol, to see which bonds have changed. it would be obvious that the C = C was broken as well as H - OH bond.
and i guess this was the approach required... sorry if i complicated things...
in short yeah...
No I think I am the one complicating things! I see what you are saying. I am taking this chemistry course online, and i am not sure that was the greatest idea! Oh well, thank God for people like you...
anytime... good luck
I think Glucose + Yeast also can become Ethanol
yeah, but in the absence of oxygen (anaerobic)
however only about 15% ethanol will be obtained...
Besides that, I noticed that Ethene + Water also can form Ethanol but 3 requirements is needed.
1. temperature 300°C
2. use H₃PO₄ as catalyst
3. pressure 65 atm
15K
