Linear algebra-linear combination
The discussion centers on determining whether the third column of the matrix [1, 2, 3; 7, 8, 9; 4, 5, 6] can be expressed as a linear combination of the first two columns. The solution involves setting up the equations a * U1 + b * U2 = x, where U1 and U2 are the first and second columns, respectively. The augmented matrix was row-reduced to [1, 0, -1; 0, 1, 2; 0, 0, 0], yielding coefficients a = -1 and b = 2. The presence of a row of zeros in the reduced matrix indicates that the third column is indeed a linear combination of the first two columns.
  • Understanding of linear combinations in linear algebra
  • Familiarity with matrix operations and row reduction techniques
  • Knowledge of augmented matrices and their interpretation
  • Basic algebraic manipulation skills
  • Study the concept of linear independence and dependence in vector spaces
  • Learn about the rank of a matrix and its implications for linear combinations
  • Explore methods for solving systems of linear equations, such as Gaussian elimination
  • Investigate applications of linear combinations in various fields, including computer graphics and data science
Students of linear algebra, educators teaching matrix theory, and anyone interested in understanding linear combinations and their applications in mathematics.
NIZBIT
For each matrix, can you write the third column of the matrix as a linear combination
of the first two columns?
[tex] \left[ \begin{array}{cccc} 1 & 2 & 3 \\ 7 & 8 & 9 \\ 4 & 5 & 6 \end{array} \right][/tex]
x=a(U1)+b(U2)
I let x equal the third column, U1 as the first column, and U2 as the second column. I solved the augmented matrix and got:
[tex] \left[ \begin{array}{cccc} 1 & 0 & -1 \\ 0 & 1 & 2 \\ 0 & 0 & 0 \end{array} \right][/tex]
which a=-1, b=2.
This where I'm confused. Do I just multiply a by the first column and b by the second then that will give me a matrix that is the linear combination wrt the third column?
A linear combination of x and y is a*x + b*y. So you want to know if you can find some a and b such that
a*first column + b*second column is equal to third column.
Can you?
Saying "third column is a linear combination of the first two columns" is the same as saying x+ 2y= 3, 7a+ 8y= 9, 4a+ 5b= 6 for some a, b, c. Can you solve those three equations? One way to solve a system of equations is to set up the "augmented" matrix and row-reduce. Do you see that you have already done that? What are x and y?
By the way, if the question was really "can you write the third column of the matrix as a linear combination
of the first two columns?" then you should have been known the answer as soon as you saw the last row.
