Thread Closed
pluto and charon
Share Thread Thread Tools
Mar9-08, 10:08 PM   #1
pluto and charon
Pluto's diameter is approximately 2370 km, and the diameter of its satellite Charon is 1250 km Although the distance varies, they are often about 1.99×104 km apart, center-to-center.
Assuming that both Pluto and Charon have the same composition and hence the same average density, find the location of the center of mass of this system relative to the center of Pluto. answer in km.
2. Relevant equations
[tex]\frac{\Sigma m*r}{\Sigma m}[/tex]
3. The attempt at a solution
i didnt know how to approach this problem since i didnt know the masses of the objects, so i treated each unit of kg in its diameter as 1 unit of m, so the mass pluto would be 2370,000*M...? (converted all units to meters, not sure if it matters)
so, since the question asks for center of mass relative to pluto center, i dont include plutos m*r since its initial position is 0.
[tex]\frac{1250,000*M*(1.99*10^{4}*1000)}{2370,000*M + 1250,000*M} [/tex]
i guess m can factor out here.
[tex]\frac{1250,000*(1.99*10^{4}*1000)}{2370,000 + 1250,000} [/tex]
this equals 6871547 meters, 6871.5 km
this is incorrect, I dont think this is correct because i just have the feeling that i dont know what I am doing here
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Mar9-08, 10:23 PM   #2
You made a very simple mistake.
You used the diameter of the objects and not the radius. Treat the objects as point masses, so the distance between the two objects surfaces plus the radius of each object is the total distance between the two.
EDIT: Also, notice that one is bigger than the other (one diameter is 2370km and the other is 1250km). Given this, one will be more massive then the other. How would you figure out how much more massive one is with respect to the other?
Thread Closed
Thread Tools
Similar Threads for: pluto and charon
Thread Forum Replies
How to calculate the momentum of Pluto? General Astronomy 6
imagine to be Pluto's surface, climate and atmosphere? General Astronomy 11
Pluto General Astronomy 10
fascination of Pluto General Astronomy 16
