Force & Energy: 5kg Block Slides 2.4m in 2s
  • Thread starter Thread starter bjohnston04
    Energy Force
A 5 kg block slides 2.4 m down a rough 30-degree incline in 2 seconds. The work done by the force of gravity is calculated using the formula W = mgh, resulting in 58.8 J, where h is determined to be 1.2 m. The change in mechanical energy due to friction is estimated using the frictional force formula Ff = μN, leading to a range of values for the work done against friction between 11.76 J and 117.6 J, depending on the coefficient of friction, μ.
  • Understanding of Newton's laws of motion
  • Familiarity with the concepts of work and energy
  • Knowledge of trigonometric functions related to right triangles
  • Ability to calculate normal force and frictional force
  • Learn about the conservation of energy principles in mechanics
  • Study the calculation of frictional forces and coefficients of friction
  • Explore the effects of incline angles on forces and motion
  • Investigate the relationship between acceleration, force, and mass using Newton's second law
Physics students, mechanical engineers, and anyone studying dynamics and energy transfer in inclined planes.
bjohnston04
Starting from rest, a 5 kg block slides 2.4 m down a rough 30 degree incline in 2 seconds. Find a) the work done by the force of gravity b) the change in mechanical energy due to friction
I'm stuck on where to start. For work, I'm using the equation w=fdcosx. I don't know what to use for f. Is the force just 9.8 or is it 9.8m? Or should i find the perpindicular force of the block? Thanks!
For a, just use the conservation of energy. You know that an object at height h has mgh potential energy.
For b, use the time taken to fall that distance to calculate the block's acceleration. Use the acceleration to figure out the net force.
- Warren
To find the work done by the force of gravity, we can use the formula W = mgh, where m is the mass of the block, g is the acceleration due to gravity (9.8 m/s^2), and h is the vertical height of the incline. In this case, the height of the incline is given by h = 2.4sin30 = 1.2 m. Thus, the work done by the force of gravity is:
W = (5 kg)(9.8 m/s^2)(1.2 m) = 58.8 J
For the change in mechanical energy due to friction, we need to consider the work done by the frictional force. We can use the same formula W = fdcosx, where f is the force of friction and x is the angle between the force of friction and the direction of motion. In this case, the angle x is 30 degrees. Now, we need to find the magnitude of the frictional force. We can use the formula Ff = μN, where μ is the coefficient of friction and N is the normal force. The normal force is equal to the weight of the block, which is mg = (5 kg)(9.8 m/s^2) = 49 N. The coefficient of friction is not given, so we cannot calculate the exact value of the frictional force. However, we can say that the frictional force is less than or equal to μN, so we can use a range of values for μ to calculate a range of values for the change in mechanical energy. For example, if we assume μ = 0.1, we get:
Ff = (0.1)(49 N) = 4.9 N
So, the range of values for the change in mechanical energy is:
W = (4.9 N)(2.4 m)(cos30) = 11.76 J to (49 N)(2.4 m)(cos30) = 117.6 J
Therefore, the change in mechanical energy due to friction is between 11.76 J and 117.6 J. It is important to note that the actual value of the change in mechanical energy will depend on the specific value of the coefficient of friction, which is not given in this problem.
  • · Replies 20 ·
  • · Replies 45 ·
