How Do Interference Patterns and Diffraction Determine Angles in Physics?
The discussion focuses on calculating interference patterns and diffraction angles using specific formulas in physics. For Problem 6, the angle of the fourth-order minimum is determined to be 0.178 degrees using the equation d sinθ = (m + 1/2)λ, with a slit separation of 0.3740 mm and a wavelength of 463.200 nm. In Problem 15, the angle for the second-order spectral line of the same wavelength is also calculated to be 0.178 degrees, employing the formula d sinθ = mλ with a diffraction grating of 3224 slits/cm.
  • Understanding of interference patterns in physics
  • Knowledge of diffraction and its mathematical representation
  • Familiarity with the concepts of wavelength and slit separation
  • Ability to perform trigonometric calculations, including inverse sine
  • Study the principles of wave interference and diffraction in detail
  • Learn about the applications of diffraction gratings in spectroscopy
  • Explore advanced topics in optics, such as the Rayleigh criterion
  • Investigate the relationship between wavelength and angle in various diffraction scenarios
Students and professionals in physics, optical engineering, and astronomy who are interested in understanding and applying the principles of interference and diffraction in practical scenarios.
mustang
Problem 6. A sodium-vapor street lamp produces light that is nearly monochromatic. If the light shines on a wooden door in which there are two straight, parallel cracks, an interfernece pattern will form on a distant wall behind the door. The slits have a separation of 0.3740mm, and the second-order maximum occurs at an angle of 0.18046 degrees from the central maximum.
determine the angle of the fourth-order minimum. Answer in degrees.
Would it be:
d sinθ = (m+1/2)λ
(0.3740*10^-3)sinθ = (m+1/2)λ does m=3?
Problem 15. By attaching a diffraction-grating spectroscope to an astronomical telescope, one can measure the spectral lines from a start and determine the start's chemical composition. Assume the grating has 3224 slits/cm. The wavelengths of the star's light are wavelength_1=463.200nm, wavelength_2=640.500 nm, and wavelength_3=704.700 nm.
Find the angle at which the second-order spectral line for wavelength 1 occurs. Answer in deg
rees.
Problem 6:
What are you going to use for λ?
Problem 15:
This is pretty much just plugging numbers into a equation. What's your question?
To solve this problem, we can use the formula d sinθ = mλ, where d is the slit separation, θ is the angle at which the spectral line occurs, m is the order of the line, and λ is the wavelength.
For the first part of the problem, we need to find the angle of the fourth-order minimum. Since we are given the slit separation (d = 0.3740mm) and the second-order maximum angle (θ = 0.18046 degrees), we can rearrange the formula to solve for the fourth-order minimum angle (θ).
d sinθ = (m+1/2)λ
0.3740mm * sinθ = (4+1/2) * λ
sinθ = 2.5 * (λ / 0.3740mm)
Now, we plug in the value of the wavelength (λ = 463.200nm) and convert it to meters (0.463200m) to get:
sinθ = 2.5 * (0.463200m / 0.3740mm)
sinθ = 3.103 * 10^-3
We can use a calculator to find the inverse sine of this value, which gives us θ = 0.178 degrees. Therefore, the angle of the fourth-order minimum is 0.178 degrees.
For the second part of the problem, we need to find the angle at which the second-order spectral line for wavelength 1 occurs. Again, we can use the formula d sinθ = mλ, and rearrange it to solve for θ.
d sinθ = mλ
0.3740mm * sinθ = 2 * (463.200nm / 3224 slits/cm)
We can convert the slit separation to meters (0.3740mm = 3.740 * 10^-4m) and the slits/cm to slits/m (3224 slits/cm = 3.224 * 10^4 slits/m) to get:
3.740 * 10^-4m * sinθ = 2 * (0.463200m / 3.224 * 10^4 slits/m)
Again, using a calculator, we find that θ = 0.178 degrees. Therefore, the angle at which
  • · Replies 34 ·
27K
