Electric Circuits: Why Power Rating of 2x 1000-W Heaters in Series is Not 2000-W
The discussion revolves around the power consumption of two 1000-W heaters connected in series to a 120 V AC voltage source. Participants are exploring why the total power consumed is not simply the sum of the individual power ratings.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants are questioning the voltage distribution across each heater in series and its effect on power consumption. There are attempts to relate resistance and power equations to the scenario.
Several participants are actively engaging with the problem, raising questions about voltage division and its implications for power. Some guidance has been offered regarding the relationship between resistance and power when devices are connected in series, but no consensus has been reached on the total power consumed.
Participants are grappling with the implications of connecting heaters in series, including the effects of voltage reduction and resistance changes on overall power consumption. There is a noted confusion regarding the application of power equations in this context.
chantalprince
The power rating of a 1000-W heater specifies the power consumed when the heater is connected dto an AC voltage of 120 V. Explain why the power consumed by two of these heaters connected in series with a voltage of 120 V is not 2000-W.
P= (V)^2/R
(?) P = IVsin^2(2 pi ft)
f= frequency
t= time
Is it because there are 2x the resistance? Therefore lowering P? In my text it starts to explain something about sinusoidal fluctuation but I don't really get how it pertains to this question, however I feel it may...
What's the voltage across each if they are in series?
I'm not completely sure, but is it 60 V each?
Right. What does that tell you?
That the watts used doesn't change.
:bugeye:
So you think that if you have a device that uses 1000W when it is hooked up to 120V it will still use up 1000W if you turned the voltage down by half? :wink:
(blush) Well, I thought that each unit was turned down by half. There are 2 heaters connected to the in the series.
Still stumped here :(
Yes.
The only way that each heater can produce 1000W (for a total of 2000W) is if each heater is given the full 120V. But we just showed that each heater gets only half the voltage, thus the total power must be less than 2000W.
Ok :) So is the total power between the 2 heaters 1000-W?
Not necessarily. You can answer that by applying one of the equations from your first post. What happens to the total resistance?
What?! I am so lost here! Ok, so if the total watts for one heater connected to 120 V is 1000 watts, and if 2 heaters are in a series with 120 V and each heater has 60 V, then wouldn't the total watts add back up to 120 and leave us where we started?
Ok, I think I got it. So P = V^2/R that gives me R = 14.4 When the voltage is cut in half then it becomes P = 60^2/14.4 so P = 250...is this correct?!
The total voltage (not wattage) would add up to 120 V. But that voltage is now spread out over both heaters. Use your power equation: P = V^2/R. If the total volts remains the same, but the resistance doubles, what happens to the total power consumed?
So R = 14.4 when voltage is 120 for ONE heater. When there are 2 R doubles. So, the total watts for the 2 heaters is 500 W?
Right. Since the total resistance doubles while the voltage remains the same, the power drops to half.
Thank you so much Doc Al!
