Transistor base-emitter voltage needed for a current to flow
The discussion revolves around the base-emitter voltage required for a current to flow through a transistor. Participants explore the theoretical and practical aspects of this voltage in various contexts, including its dependence on temperature and current, as well as its implications for transistor applications.
  • Some participants suggest that a base-emitter voltage of approximately 0.65 volts is a good first-order approximation for current flow, noting that this value can vary with temperature and current levels.
  • Others argue that any forward voltage can initiate current flow from base to emitter, but low voltages result in very small currents.
  • A participant mentions that even with a base-emitter forward voltage drop of zero volts, some collector current can still flow due to leakage currents, referred to as "Iceo" and "Icbo".
  • There is a discussion about the practical application of transistors, emphasizing that a low base current with a low base-emitter voltage may not be useful in real-world scenarios.
  • Some participants highlight that the typical operating range for a transistor in linear amplification is around 0.60 to 0.70 volts for the base-emitter voltage.
Participants generally agree on the approximate value of 0.65 volts as a starting point for the base-emitter voltage, but there are competing views regarding the implications of lower voltages and the practical applications of transistors. The discussion remains unresolved on the broader implications of very low base-emitter voltages.
Participants express varying interpretations of the original question, with some focusing on practical applications while others consider theoretical aspects. The discussion includes references to leakage currents and their effects, which may not be universally acknowledged in all contexts.
Amy54
what base-emitter voltage is needed for a current to flow through the trasnsistor?
One forward p-n junction drop, about 0.65 volts, as the b-e junction is just a forward biased diode. This varies with temperature and current. At high temp and low current, the Vbe may fall to 0.50 V, and may exceed 0.80 V at low temp and high current. But, 0.65 V is a good first order approximation to use as a starting point. I hope this helps.
Claude
This was discussed in stewarcs's reference (see Base-Emitter Junction Details)
In reality, any forward voltage will make current flow from base to emitter, but low voltages will originate very small currents.
No matter what answer I give, someone can always "one up" me and add something I omitted. So allow me to return the favor. Even with a base-emitter forward voltage drop of *zero* volts (b-e short-circuited), some collector current will indeed flow. This is "Iceo", and if the base-emitter junction is open, the current is "Icbo". These are leakage currents from the reverse biased collector to base and emitter terminals.
I interpreted the OP's question from a practical utilitarian sense that one uses a transistor to obtain power gain greater than unity. If a low powered signal source such as a microcontroller, transducer, etc. is used to actuate a higher powered device such as a solenoid, lamp, motor, etc., operating a bjt with Ib = 250 nA, & Vbe = 0.40 V is of no practical use. It was understood by me that the OP intended for the bjt to do something useful. If the bjt application is that of linear amplification, the dc bias point, or "quiescent point", is generally in the neighborhood of 0.10 to 10 mA, and 0.60 to 0.70 V.
Unless one is using the bjt as the logging element in a logarithmic amp/converter, Vbe = 0.65 V give or take a tad, twice that for a Darlington, is where it operates. When using a bjt as a switch or an amplifier, the 0.65 V value for the Vbe forward drop is a *darn good* first order approximation. Peace and BR.
Claude
Claude
I was not nitpicking your post. The 0.6 to 0.7 V figure is in any elementary book about transistors, so I don't think anyone would ask such a question in this forum. I supposed that the OP was interested in knowing if a very small voltage would produce a base current independently of any practical application.
  • · Replies 59 ·
  • · Replies 17 ·
