What is the Shortest Timed Path for a Body to Reach Two Points in Space?
  • Thread starter Thread starter puneeth
    Path
The shortest timed path for a body to travel between two points in space at different heights is a cycloid. This conclusion is derived from principles of calculus of variations, specifically using the Euler-Lagrange equation to minimize the time integral. A body following this cycloidal path takes approximately 25% less time to reach the lower point compared to a straight-line trajectory. The discussion emphasizes the application of energy conservation and the relationship between speed and height in deriving the solution.
  • Calculus of Variations
  • Euler-Lagrange Equation
  • Basic Kinematics (speed and height relationship)
  • Energy Conservation Principles
  • Study the derivation of the Euler-Lagrange equation in detail.
  • Explore cycloidal motion and its applications in physics.
  • Learn about energy conservation in non-linear trajectories.
  • Practice solving calculus of variations problems with different boundary conditions.
Students and professionals in physics, particularly those focusing on mechanics and optimization problems, as well as mathematicians interested in calculus of variations.
puneeth
A frictionless path is set up between two points in space at different heights, such that a body released from the higher point along this path takes minimum possible time to reach the lower point. Show that the path is a cycloid. Also show that a body released along this path takes about 25% lesser time as compared to traveling along a straight path.
Energy conservation,
Let us assume that the total height difference is H and the horizontal distance is X.
when the body falls through a height y its speed is [tex]\sqrt{2gy}[/tex]
[tex]\frac{dx}{dt}[/tex]= vcos[tex]\theta[/tex]
[tex]\frac{dy}{dt}[/tex]= vsin[tex]\theta[/tex]
i am unable to integrate and apply the condition for minimum time- please help.
This is a calculus of variations problem. If you write the curve as y=f(x) you want to express the time to fall as an integral expression involving f. Then change it into a differential equation using Euler-Lagrange. Then solve the differential equation.
13K
