Rocket Thrust From a Spring (Work)
The problem involves a weather rocket attached to a spring, focusing on the dynamics of thrust and energy conservation. Participants are exploring how to calculate the rocket's speed after the spring has stretched, considering various forces and energy contributions.
  • Mixed
  • Participants discuss using energy conservation equations, including work done by thrust and potential energy from the spring and gravity. There are attempts to derive the rocket's speed using different methods, including kinematics and energy principles.
Multiple participants are exploring different interpretations of the problem, with some suggesting that the spring's energy should be included in the calculations. There is no explicit consensus on the correct approach, as various answers have been proposed and debated.
Participants are questioning the assumptions regarding the forces acting on the rocket, including thrust, spring force, and gravitational force. There is also discussion about the effects of non-constant acceleration due to the spring's behavior.
sam2k2002
A 11.7 kg weather rocket generates a thrust of 240 N. The rocket, pointing upward, is clamped to the top of a vertical spring. The bottom of the spring, whose spring constant is 560 N/m, is anchored to the ground.
(a) Initially, before the engine is ignited, the rocket sits at rest on top of the spring. How much is the spring compressed?
20.5cm (.205m)(b) After the engine is ignited, what is the rocket's speed when the spring has stretched 33.0 cm?
2.87m/s(c) For comparison, what would be the rocket's speed after traveling this distance if it weren't attached to the spring?
This is the question I have a problem with.
Ug = mgh
Us = 1/2 k (delta_x)^2
KE = 1/2mv^2
W_thrust = F_thrust*distance
Ok, so for Part (b) I used the following equation to find the velocity:
W_thrust + U_s(using x_1) = U_s(using x_2) + U_g + KE
I was able to solve for the v in KE correctly using this equation. So in order to find the velocity of the rocket when the spring is taken out, I take the U_s out of the equation:
W_thrust = U_g + KE Where the distance here will be x_1 + x_2. (x_compressed + x_stretched = x_total)
I've done this problem a number of ways.. work, energy, kinematics.. and i keep arriving at the (incorrect) answer v = 3.38m/s. Can anyone help me spot my error? Thanks in advance.
-Sam
I think the answer is 3.79 m/s
Nope, that doesn't work.
Here's what i have for the energy equation.
Work_thrust = U_g + KE
(240N)(.535m) = (11.7kg)(9.81)(.535m) + 1/2(11.7kg)v^2
With that equation I get 3.38m/s, which is wrong. Maybe I'm using the wrong height? The problem asks for the velocity at the height of the previous question, where x1 was -.205m and x2 was +.33m, so the deltaX would just be .535, right?
I think I figured out the problem, one sec...
Ok, I get 3.79 m/s. Is this correct?
If it is, then I am pretty sure that I know what you did wrong and why all the other methods you used gave you the same answer.
Nope.. That was my last attempt, the answer turned out to be 3.67. Any idea what we're doing wrong?
I thought thrust was a force. Knowing force and mass, we know the rocket's acceleration. Knowing that, we know velocity at any given distance. Where am I going wrong?
f=m*a
(240)=(11.7)*a
a=20.5128
dx/dt^2=a
dx/dt^2=20.5128
0.33/dt^2=20.5128
dt^2=0.0161
dt=0.1268
dx/dt=2.6018 m/s
f=m*a
(240)=(11.7)*a
a=20.5128
dx/dt^2=a
dx/dt^2=20.5128
0.33/dt^2=20.5128
dt^2=0.0161
dt=0.1268
dx/dt=2.6018 m/s
You're forgetting gravity.
Nothing after dx/dt^2=a makes sense. This is a second order differential
equation, of which the solution is x = (1/2) a t^2
I think the spring will still push against the rocket, so you can add the energy of
the compressed spring to the rocket.
I just came within 0.262% of that number
3 components of force going on here:
1) the rocket's thrust
2) the spring's push (as kamerling says, the spring is still pushing)
3) the Earth's pull
1)
acceleration from rocket thrust
f=ma
240=11.7a
a=20.5128
2)
acceleration from spring's push
f=-kx
f=-(-0.205)(560)
f=114.8
f=ma
114.8=(11.7)a
a=9.812
3)
the Earth's pull
a=-9.8
Now add them all up and you get
a=20.5248
x(t)=(1/2)a*t^2
0.33=(1/2)(20.5248)*t^2
t=0.1793
v(t)=at
v=20.5248*.1793
v=3.68
error margin of 0.272%
3) the Earth's pull
1)
f=ma
240=11.7a
a=20.5128
2)
f=-kx
f=-(-0.205)(560)
f=114.8
f=ma
114.8=(11.7)a
a=9.812
3)
the Earth's pull
a=-9.8
a=20.5248
x(t)=(1/2)a*t^2
t=0.1793
v(t)=at
v=20.5248*.1793
v=3.68
The acceleration of the spring isn't constant. The acceleration of the spring only works from x= -20.5 up to x=0. You only computed x and v when x>=0, but the initial position of the rocket is at -20.5.
Because of the non-constant acceleration of the spring it's rather hard to compute x(t) or v(t) and it's easier to compute the kinetic energy of the rocket, which comes from.
- The energy of the compressed spring.
- The force of the rocket engine which acts over a 0.535 m stretch.
- The force of gravity which also acts over a 0.535 m stretch, but in the opposite direction of the velocity, so its contribution is negative.
If you add these up, and use (kinetic energy) = (1/2)mv^2 you get the right answer.
