What is the answer to the Twins Paradox confusion in relativity?
The discussion centers around the Twins Paradox in the context of relativity, specifically addressing the confusion regarding aging and simultaneity between observers in different inertial frames. Participants explore the implications of constant relative motion and the nature of time as perceived by different observers.
  • One participant questions how the paradox is resolved if two observers are in constant relative motion without turning around, noting that each perceives the other's frame as moving slower.
  • Another participant suggests that the aging process is frame-dependent and not directly comparable between observers, indicating that simultaneity is not objective in relativity.
  • There is a claim that asking who is "really" older is problematic due to the frame-dependent nature of such questions in relativity.
  • Some participants express confusion over the implications of constant light speed in inertial versus accelerated frames, with one confirming that light speed does not have to be constant in accelerated frames.
  • One participant challenges the notion that objects age differently, asserting that any object with a clock can be said to age in a manner similar to humans.
  • Several posts introduce analogies, such as using a tape recorder, to illustrate concepts of time and perception, though their relevance to the main question is questioned by others.
Participants express differing views on the nature of aging and simultaneity in relativity, with no consensus reached on how to interpret the implications of the Twins Paradox. The discussion remains unresolved regarding who is older in the scenario presented.
Participants highlight the complexity of simultaneity and aging in different reference frames, indicating that assumptions about time and motion may vary significantly based on the observer's frame of reference.
Xeinstein
I am having trouble understanding how the explanation of the paradox solves the problem. What if people in two different frames were moving wrt one another with constant velocity. Say for instance, these people never turn around to meet up once again and are constantly moving at a constant velocity wrt one another.
Clearly, each will percieve the other's frame to be moving more slowly than their own. There is never a change in reference frame so they disagree on who is older. Who is actually older? Are they both younger and both older simultaneously? That seems to be a weird consequence of relativity. What am I missing here?
Also, I know the speed of light is constant in all inertial frames. However, it does not necessarily have to be constant in accelerated frames, correct? I believe this because the postulate of relativity states that "all laws of physics are the same in all inertial reference frames", so some laws of physics are not the same in accelerated reference frames, and therefore the speed of light is not necessarily constant in all reference frames, but it is only constant in inertial frames?
Your just making it harder for your self by thinking of it that way...
your missing that things don't age like we do... objects age only by observing the difrence from one preceptable frame to another :/ please refine your other questions :/
Simultaneity between distant events isn't objective in relativity, that's what is meant by the relativity of simultaneity--If we are light-years apart, then in one frame the event of my turning 30 can be simultaneous with the event of your turning 40, in another frame the event of my turning 30 can be simultaneous with the event of your turning 20. Asking who is "really" older in this case would be like asking which of two objects moving slower than light is "really" moving at a greater speed, in relativity these questions are frame-dependent so there simply is no single correct answer.
That's correct.
That doesn't really make any sense. Any object that you can attach a clock to can be said to age exactly like we do, with the age just defined as the elapsed time on the clock.
play with a tape recorder, and record your self talking at a slower turning speed. then play it back at a faster turning speed. your voice would be slower. do the oppisite and it would be faster
What do tape recorders have to do with Xeinstein's question?
  • · Replies 24 ·
  • · Replies 43 ·
  • · Replies 35 ·
  • · Replies 137 ·
11K
  • Sticky
9K
