Register to reply
Gravity field phenomenon is the curved light ray ?
by einsteinooo
Tags: curved, field, gravity, light, phenomenon
Share this thread:
einsteinooo
#1
Mar16-08, 11:43 PM
P: 5
Surrounding the planets usually exists the various atmosphere. Due to this atmosphere, one light ray crossing the planet will be refracted more if it comes more closely to the planet's surface. So how to know that " gravity field phenomenon is the curved light ray" is not created by the planets' atmosphere ?
Phys.Org News Partner Physics news on Phys.org
Step lightly: All-optical transistor triggered by single photon promises advances in quantum applications
The unifying framework of symmetry reveals properties of a broad range of physical systems
What time is it in the universe?
mgb_phys
#2
Mar16-08, 11:49 PM
Sci Advisor
HW Helper
P: 8,953
Planets are not normally used to measure gravitational lensing.
The atmosphere is a problem and they don't have enough mass to give a significant result.
ZapperZ
#3
Mar17-08, 06:48 AM
Emeritus
Sci Advisor
PF Gold
ZapperZ's Avatar
P: 29,238
Quote Quote by einsteinooo View Post
You forgot to ask why there are atmosphere around a planet in the first place.
There's one simple way to check for this. Put an object in an environment of "less atmosphere" and check its weight. If it has changed considerably as you pump out the air, then you'd be correct. I have a vacuum chamber that can go to as low as 10^-10 Torr. How much are you willing to bet that a block of, say, OFE copper that I put in there would be reduced in mass as I pump it down?
Zz.
einsteinooo
#4
Mar17-08, 09:44 PM
P: 5
Atmosphere is " Sphere lens "
ZapperZ
#5
Mar19-08, 08:10 AM
Emeritus
Sci Advisor
PF Gold
ZapperZ's Avatar
P: 29,238
So where is this "sphere lens" when I pump out a lot of it, yet my object still weighs the same?
Zz.
Register to reply
Related Discussions
Gravity AND curved space-time bending light Special & General Relativity 2
Shining Light - The Physics Behind This Phenomenon? General Physics 9
Does light have its own gravity field? Special & General Relativity 20
How can magnetic field be a relativistic phenomenon? Special & General Relativity 8
Gravity caused by curved space - am I right? Special & General Relativity 18
