How Does Impulse Affect the Motion of a Rotating Rod on a Frictionless Table?
  • Thread starter Thread starter discoverer02
    Rod Rotating
The discussion focuses on the dynamics of a uniform rod of mass M and length L subjected to an impulse J on a frictionless table. The initial horizontal velocity of the center of mass (CM) is determined to be Vcm = J/M, while the velocity of the lower end of the rod is calculated to be Vtan = 4J/M after considering the motion of the CM. The angular velocity w is found to be 6J/(ML), and the distance the CM moves horizontally during one complete revolution is piL/6. The discrepancies with textbook answers are clarified through a detailed analysis of the moment of inertia and the reference point for angular momentum.
  • Understanding of impulse and momentum concepts
  • Knowledge of angular momentum and moment of inertia
  • Familiarity with rotational motion equations
  • Basic principles of dynamics on frictionless surfaces
  • Study the derivation of moment of inertia for different axes, particularly for rods
  • Learn about conservation of angular momentum in various systems
  • Explore the relationship between linear and angular velocities in rotational dynamics
  • Review impulse-momentum theorem applications in physics problems
Students preparing for physics exams, educators teaching dynamics, and anyone interested in the principles of rotational motion and impulse effects on rigid bodies.
discoverer02
Here's the problem:
A uniform rod of mass M and length L stands vertically on the edge of a frictionless table. A blow of impulse J is applied horizontally at the lower end of the rod.
a) What are the initial horizontal velocity of the CM of the rod relative to the table, and the velocity of the lower end of the rod relative to the table?
b) How far does the CM of the rod move horizontally in the time the rod rotates one revolution?
w = angular velocty of rod.
I = moment of inertia of rod
Vcm = velocity of CM of rod
Vtan = velocity of end of the rod
OK, I place the origin at the bottom of the rod so that angular momentum is conserved.
Iw = (L/2)MVcm
[(1/12)ML^2]w = (L/s)MVcm
Impulse in x direction is equal to the change of momentum in the x direction so: Vx = Vcm = J/M
w = 6J/(ML) so Vtan = 3J/M => My textbook says it's 4J/M
Plug w back into the equation above and you get.
Vcm = J/(2M) => Textbook says it's J/M
b) Using the above I get piL/6
I've thought about the problem pretty carefully and can't see why my answers don't agree with the book.
Can someone please check them.
Thanks.
You're very close -- I think you're just being a little inconsistent.
You already said "Impulse in x direction is equal to the change of momentum in the x direction so: Vx = Vcm = J/M", and that's correct. So you already have the textbook answer for that part of the question. But then you went on and contradicted yourself a few lines later!
As to the rotational motion, you say "I place the origin at the bottom of the rod so that angular momentum is conserved" but I don't think you actually did that. Actually, you placed your axis of rotation at the center of mass, not the bottom of the rod (and anyway, that's OK). Notice that you used the moment of inertia about the center of mass, (ML^2)/12. If you were figuring rotation about the end of the rod, you would have to use (ML^2)/3.
You got w = 6J/ML which is correct, for rotation about the cm. And since Vtan=rw, and for rotation about the cm, r = L/2, Vtan=3J/M, just as you said.
The only thing you really missed is that since your Vtan of 3J/M is relative to the cm, and the cm is moving along at a velocity of J/M relative to the table, the velocity of the lower end of the stick relative to the table is 3J/M + J/M = 4J/M.
The rest is just arithmetic.
(Keep 'em coming. My physics final is 9 days away & you're giving me a great review.)
:smile:
Thanks again Gnome,
I should have seen that I solved for Vtan with respect to the CM of the rod and not the table and also that I already Vcm = J/M. I've been working on these problems all day gearing up for a test this Wednesday and I'm confusing myself a bit.
I've posted another problem that I'm not quite able to work out.
  • · Replies 31 ·
  • · Replies 25 ·
