Where are the Higgs boson particles
The discussion revolves around the nature and implications of the Higgs boson and Higgs field, exploring questions about their theoretical existence, their role in particle mass, and the distinctions between scalar particles and other types of particles. Participants delve into concepts related to mass generation, the properties of scalars, and the relationship between the Higgs mechanism and other phenomena in physics.
  • Some participants propose that the Higgs boson is a scalar field present everywhere, while others challenge the definition of scalars, arguing that scalars can have mass and interact strongly.
  • There is a contention regarding the nature of scalar particles, with some asserting that massless scalars can move at the speed of light, while others argue that this is not universally true.
  • Participants discuss the role of the Higgs boson in explaining the mass of weak interaction bosons (Z and W) and the potential for it to also explain fermion masses, though this remains debated.
  • Questions are raised about how massless scalars acquire mass and the implications of this for the Higgs mechanism, with references to the hierarchy problem in the Standard Model.
  • Some participants express uncertainty about the relationship between the Higgs mechanism and concepts like dark matter and dark energy, suggesting these are distinct issues.
  • There is a discussion about the theoretical status of the Higgs field and boson, with acknowledgment that they are part of a broader set of models in particle physics.
Participants exhibit disagreement on several points, particularly regarding the properties of scalar particles and the implications of the Higgs mechanism. There is no consensus on how massless scalars become massive or the relationship between the Higgs boson and other theoretical constructs.
Limitations include varying definitions of scalars, differing interpretations of the Higgs mechanism, and unresolved questions about the mass of particles and the implications for cosmological phenomena.
jal
Where are the Higgs boson particles supposed to be located?
Is there one in the electron, neutrinos, proton, neutron?
jal
everywhere, it is a scalar field.
It is similar to the question if the leptons carries Z and W bosons inside.
hummmm!
Let see... scalars are massless or weakly interacting.
A higgs particle has mass. Therefore, it is no longer a scalar.
Saying that it is "a massive scalar particle" is mixing apples and oranges.
http://en.wikipedia.org/wiki/Higgs_boson
The best explanation that I have see, which tries to explain how the Higgs bosons can "create mass", is the work by A. Garrett Lisi and E8.
http://arxiv.org/abs/0711.0770
However, I cannot figure out how this scalar can be "one fits all".
He addresses the questions for the neucleons but he nor anyone else have anything to say for electrons, and neutrinos.
jal
What !? Why do you say that !? The pions are (pseudo)scalars for instance and very strongly interacting.
The best explanation that I have see, which tries to explain how the Higgs bosons can "create mass", is the work by John G. and E8.
Ah I get it, this is a joke :-p
I beg to differ. Many people have a lot to say about hadrons.
yes Jal, the higgs bosons are ought to believe only 'explain' the mass of the weak interaction bosons (Z and W). But some also thinks it can explain the fermion masses.
See also this thread: https://www.physicsforums.com/showthread.php?t=218500&highlight=Higgs
The thing is, that particles don't live inside each other, that is a very naive view.
Hi humanino !
I realize that the Higgs field and the Higgs boson are still theoretical and only one out of many possible models.
I looked up all of the words that you used.
scalars at http://en.wikipedia.org/wiki/Scalars ,
I just want to keep things simple. If it’s massless it can move at the speed of light.
If it has mass then it is subluminar.
pions at http://en.wikipedia.org/wiki/Pion ,
pseudoscalar at http://en.wikipedia.org/wiki/Pseudoscalar_(mathematics) scalar fields at http://en.wikipedia.org/wiki/Scalar_field .
Hadrons at http://en.wikipedia.org/wiki/Hadrons
Then I looked up
Lepton http://en.wikipedia.org/wiki/Lepton
This is where I found the electrons and the neutrinos.
Here is what they said, “The masses of the leptons also obey a simple relation, known as the Koide formula, but at present this relationship cannot be explained.”
How is the Higgs particle mechanism responsible for the mass of electrons, neutrinos and as well as the mass of ALL particles?
Should I, also, be asking if Higgs mechanism has anything to do with Dark Matter and Dark Energy?
Under scalar fields it says,
“ In the Standard Model of elementary particles, a scalar field is used to give the leptons their mass, via a combination of the Yukawa interaction and the spontaneous symmetry breaking. This mechanism is known as the Higgs mechanism [1]. This supposes the existence of a (still hypothetical) spin 0 particle called Higgs boson.”
“Scalar fields are supposed to cause the accelerated expansion of the universe (inflation [8]), helping to solve the horizon problem and giving an hypothetical reason for the non-vanishing cosmological constant of cosmology. Massless (i.e. long-ranged) scalar fields in this context are known are inflatons. Massive (i.e. short-ranged) scalar fields are proposed, too, using for example Higgs-like fields (e.g. [9)”
Hi malawi_glenn
Yes, I have been following the different threads.
jal
They are most favored in the current paradigm.
scalars
A scalar particle just refers to a particle without spin. The Higgs boson is unique in the sens that it is a fundamental particle without spin.
Let us not concentrate on neutrinos for now as they would just complicate the story. Fundamental matter particles (fermions) are the quarks and leptons. The gauge principle, which is a powerful symmetry principle based on the (classical electromagnetism, later generalized to a quantum)[/size] idea that the wave function absolute phases (as a complex number) are arbitrary at every point in space-time, forbids mass terms in the lagrangian. The mass terms can be constructed from a (Higgs) scalar field. This Higgs scalar field however is first motivated by the "force" sector of the model, describing gauge bosons.
What we have been referring to sometimes is the contradistinction between "normal" mass around us, which is not explained by the Higgs boson, and fundamental particles mass terms in the lagrangians (which are very important for the model to make sens).
The Dark Matter and Energy are yet two other very distinct and important puzzles from Cosmology. Particle physicists of course show interest in those as well. But the scalar inflaton you are referring to is not the same (to my inderstanding) as the Higgs boson(s).
Sorry if my post is too general. I am not sure what is the level of the discussion here.
Zapper is looking over my shoulder. :cool:
First, my thanks and respect for taking all of the time that you do to try to communicate with all levels of amateurs. It's a challenging task.
My wiki references are to help communication with other amateurs.
A scalar particle just refers to a particle without spin. The Higgs boson is unique in the sense that it is a fundamental particle without spin.
... But the scalar inflaton you are referring to is not the same (to my inderstanding) as the Higgs boson(s).
I agree.
The word "scalar" seems to over used. Can we generalize it as I did...
I've got to do "living chores". I'll be back later.
Thanks
jal
Hi humanino !
I guess that I should have started by asking a different question and not worry about the mass of neutrino and electrons.
How did the massless scalars acquire mass and become Higg particles which then give mass to the other massless scalars which then become particles.?
I could not find any papers in arXiv.org that dealt with this question.
jal
jal
There is nothing bad about a scalar field getting a mass - unlike fermions or gauge bosons, there is no symmetry to forbid it, discounting things like "supersymmetry". In fact, the right question to ask is: "Why is the scalar Higgs boson mass so SMALL?" Naively, you would expect it to be close to the Planck mass due to quantum corrections! That's where the "hierarchy problem" of the Standard Model appears.
So in summary: scalar particles normally *WANT* to be as heavy as they could be. So there's no puzzle here.
Hummmm!
You said, "scalar particle". From what I have learned, scalars move at the speed of light and particles are sub-luminar. How was this change achieved?
jal
jal said:
Hummmm!
jal
I don't think what you've learned is correct. Scalars don't necessarily move at the speed of light, and if you mean "subluminal", the second part of your sentence doesn't make logical sense since scalars - shorthand for "scalar particles" - are a subset of particles.
jal said:
Hummmm!
jal
MASSLESS particles (scalars, spinors, vectors, tensors, etc) move at the speed of light. Anything with a mass (scalars, spinors, vectors, tensors, etc) does not.
  • · Replies 16 ·
