Optics Problems: Concave Mirrors and Refraction Calculations
  • Thread starter Thread starter Prime
The discussion revolves around optics problems involving concave mirrors and refraction calculations. The original poster presents two specific problems: one concerning the image formation by a concave mirror and the other regarding the refraction of light through a glass plate.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the relationship between object distance and radius of curvature for concave mirrors, questioning how these distances relate to image characteristics. There are inquiries about the application of the laws of reflection and the conditions for real versus virtual images. For the refraction problem, participants suggest recalling relevant formulas and concepts related to angles of incidence and refraction.
The discussion is ongoing, with participants providing guidance on drawing diagrams and applying relevant equations. Some participants express confusion about the problems, indicating a need for further clarification and support. There is no explicit consensus on the approaches yet, as multiple interpretations and methods are being explored.
Participants note that the problems are not graded and emphasize the importance of showing work to facilitate assistance. There are mentions of using various sources to aid in understanding the problems.
Prime
HElp ME PLEASE
Hello my name is Scott Johnson I was just wondering if u could help me with thse two problems I am stuck on. I have I deadline for tomorrow so if u could email me back today that would be great.greatlt apprecated
1) a 0.50 cm high object is placed 30 cm in front of a concave mirror that has a 15cm radius of curvature. a)find the position and size of the image and state whether it is real or virtual and upright or inverted. Repeat the distances of b) 15 cm, c) 12 cm, and d) 6 cm. check your calculations with ray diagrams. (20 pts for each letter section)
2)Light at an incident ray of 37degrees enters a flat glass plate (n=1.50). a)what is the angle of refraction inside the glass? b) after the beam leaves the plate, what is the angle between it and the beam incident on the plate? (10 pts for each letter section)
Prime,
Forum rules state that for us to help you, you need to show your work and where you got stuck.
It does absolutely nothing for you if someone gives you the answer, and is considered cheating if the problem is graded.
So post what you've tried, and we'll help you out.
its not graded.
if u place a .50cm high object in frount of a 30 concave mirrior the curauture of it woul dbe 15 cm in radios
so would this mean that because the distance form the mirroir is cut in half the equals the radious. And would u do that for all of them
most of it makes no sense to me, my teacher gave me this question to see if we were deciated to our work..any sorce made be used in these questions that's why i posted it
its not graded.
if a .50 cm high object is placed 30 cm in front of a concave mirrior that has 15 cm radious curature.
does this mean that the distance between the mirrior and the object its cut in half to equal the radious?
this is not graded it is just a problem that our teacher has given us to see if were deciated to our work. Any sorces our availbe for uses. Thats why i posted it please help me. Please
this is the problem i can't understand this
For question 1a, draw a concave mirror and an object on your graph paper. You should apply the laws of reflection in this case. Light rays from the object parallel to the principle axis will pass through the focus, and vice versa. Repeat the above steps to do part b, c and d. When will the image be real/virtual ?
Here is a link for your reference.
For question 2, I think you have learned a formula relating angle of incidence, angle of refraction and refractive index, right? Try to apply that formula.
more
can u give me a little more info
Start with 1. recalling thin lens (thin mirror) equation and 2. relationship between radius of curvature and focal length for a mirror.
Yeah, this is prolly too late, but some equations to get you started:
f=r/2 where r is the radius of curvature..
and
1/di + 1/do=f
Keeping in mind that the focal distance is negative for diverging instruments and positive for converging ones.
Prime,
Welcome to Physics Forums.
I merged your two threads together into a single thread. In the future,
1. In the Homework Help forum, please show us some of your work.
2. Please start only one thread per problem.
Thanks,
  • · Replies 16 ·
9K
